ratser map based on CGI
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Wed May 31 09:59:04 EDT 2006
Zhonghai: That should be doable. The CGI does accept a point (only in map coordinates I think) and a scale. You'd probably want to allow panning in the the main map display (no zooming) and then control scale with a seperate form. A skeleton browse template might look like (this is off the top of my head):
<form name=image_form action=/cgi-bin/mapserv>
<input type=hidden name=map value=[map]>
<input type=hidden name=imgext value="[mapext]">
<input type=image name=img src=[img]>
</form>
<form name=scale_form action=/cgi-bin/mapserv>
<input type=hidden name=mapxy value="[mapx] [mapy]">
<select name=scale SINGLE>
<option value=1000000> 1:1,000,000
<option value=500000> 1:500,000
</select>
<input type=submit name=" go ">
</form>
You'd have to maintain the scale select list state with a bit of javascript but otherwise something like this should work. Since the forms are pretty well self contained you should be able to use most any design/page layout.
Steve
>>> Zhonghai Wang <zhonghaiw at GMAIL.COM> 05/31/06 3:18 AM >>>
Hi guys,
trying to develop a small demo using scanned paper maps, these are some
historical maps and scanned as GIF or JPEG format. I am wondering if I can
do it only using HTML tags and CGI parameters, without client side script
languages.
the problem for these paper maps is:
I can not use the zoom[number] parameter to set the zoom control, since each
paper map can only be displayed in a certain map scale, e.g 1:1000000,
otherwise it's not readable because of the image resolution. I have about 9
different levels.
I appreciate your info.
zhonghai
31.05.2005
