Problem: ANGLEITEM and TRANSPARENT
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Wed May 31 10:04:56 EDT 2006
As a follow up. The patch was not as complete as I hoped. I worked on the problem until late last night but did not end up committing anything- still working on it though.
Steve
>>> Steve Lime <Steve.Lime at DNR.STATE.MN.US> 05/30/06 1:01 PM >>>
Christian: The problem seems to be in GD. Transparency is lost after rotation and I've tried a variety of methods
to rebuild it post rotation and it simply doesn't work. That said, the folks have MapMedia have submitted a new
image rotation function that should fix the issue and some others with resampling method. I need to integrate
that into the development version for testing. I will do that tonite...
Steve
>>> Christian Wilmes <C.Wilmes at GMX.DE> 5/30/2006 8:11:39 AM >>>
Hi All,
I'm trying to visualize point-data with the mapserver. As symbol I'm using a transparent PIXMAP. Now I want to use ANGLEITEM in the STYLE-Object, ANGLEITEM itself is working fine, but using it causes the lost of the transperency. Instead of the parameter TRANSPARNZ in the SYMBOL-Object I also tried it with a gif and a png which has already a transparent background. The result is the same, without ANGLEITEM it works fine but without it doesn't.
Does anybody have an idea how to fix that problem?
Best Regards
Christian
Bis zu 70% Ihrer Onlinekosten sparen: GMX SmartSurfer!
Kostenlos downloaden: http://www.gmx.net/de/go/smartsurfer
