debug info with 4.9
John Cole
john.cole at UAI.COM
Wed May 31 12:13:40 EDT 2006
I'm using mapserv 4.9 from the latest FWtools for linux and I would like to
see the debugging info. I've copied over a map file from a w2k3 server with
mapserver 4.8.0 that prints out the timing information at the bottom of the
web page, but this doesn't appear with 4.9.
What do I need to set in order to get the same information in 4.9?
I have DEBUG on and have tried it with and without a LOG file set in the WEB
section (no logfile is ever created either, as it is in 4.8).
Thanks,
John Cole
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
