Problem with wfs_filter
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed May 31 12:59:05 EDT 2006
Christian,
if you do the GetFeature request inside your browser do you get any
result ? If the filter is not set, do you get results back ?
Christian Wilmes wrote:
> Hi All,
> I've set up a WFS with "VirtualSpatialData" and thought everything is working fine, but now I have to assert, a WMS-Layer on the WFS with a "wfs_filter" doesn't work. Whatever I'm typing in the wfs_filter there will not be just one point in my Layer.
> In the log-file I found the following:
> [Tue May 30 09:37:06 2006] [error] [client 127.0.0.1] HTTP: Starting to prepare HTTP requests.\r
> [Tue May 30 09:37:06 2006] [error] [client 127.0.0.1] HTTP request: id=4, http://localhost/cgi-bin/mapserv.exe?&REQUEST=GetFeature&VERSION=1.0.0&SERVICE=WFS&TYPENAME=myWFS&FILTER=%3CFilter%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3Etyp%3C%2FPropertyName%3E%3CLiteral%3EREFERENCE%3C%2FLiteral%3E%3C%2FPropertyIsEqualTo%3E%3C%2FFilter%3E\r
> [Tue May 30 09:37:06 2006] [error] [client 127.0.0.1] HTTP request: id=4, found in cache, skipping.\r
> [Tue May 30 09:37:06 2006] [error] [client 127.0.0.1] HTTP: Before download loop\r
> [Tue May 30 09:37:06 2006] [error] [client 127.0.0.1] HTTP: After download loop\r
> [Tue May 30 09:37:06 2006] [error] [client 127.0.0.1] msHTTPExecuteRequests() timing summary per layer (connect_time + time_to_first_packet + download_time = total_time in seconds)\r
> My mapfile for the WFS:
> MAP
> NAME WFS_Server
> STATUS ON
> WEB
> IMAGEPATH "c:/ms4w/tmp/ms_tmp"
> IMAGEURL "/ms_tmp/"
> METADATA
> "wfs_title" "WFS Server"
> "wfs_onlineresource" "http://127.0.0.1/cgi-bin/mapserv.exe?"
> "wfs_srs" "EPSG:31467"
> END
> END
> PROJECTION
> "init=EPSG:31467"
> END
> CONFIG "PGSQL_OGR_FID" "id"
> DEBUG ON
> LAYER
> NAME myWFS
> DUMP TRUE
> DEBUG ON
> METADATA
> "wfs_title" "myWFS"
> "gml_include_items" "all"
> END
> TYPE POINT
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION "PostgreSQL.ovf"
> PROJECTION
> "init=EPSG:31467"
> END
> END
> END
> The WMS-Layer:
> LAYER
> NAME "RosoftWFS"
> TYPE POINT
> STATUS ON
> DEBUG ON
> CONNECTIONTYPE WFS
> CONNECTION "http://localhost/cgi-bin/mapserv.exe?"
> METADATA
> "wfs_typename" "myWFS"
> "wfs_version" "1.0.0"
> "wfs_request_method" "GET"
> "wfs_service" "WFS"
> "wfs_filter" "<PropertyIsEqualTo><PropertyName>typ</PropertyName><Literal>REFERENCE</Literal></PropertyIsEqualTo>"
> END
> PROJECTION
> "init=EPSG:31467"
> END
> CLASS
> NAME test
> SYMBOL "Punkt"
> SIZE 10
> COLOR 255 0 0
> END
> END
> I would be very thankful for any help!
> Best Regards
> Christian
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
