oracle spatial and mapserver problem
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Sat Apr 7 09:16:47 EDT 2007
I have gotten it to wor with a small sh script:
cat /usr/lib/cgi-bin/mapserv410a
#!/bin/sh
export TNS_ADMIN=/home/swoodbridge/.oracle/
export ORACLE_HOME=/home2/oracle/cl10/
export LD_LIBRARY_PATH=/home2/oracle/cl10/lib/
/usr/lib/cgi-bin/mapserv410 $*
I believe apache does not pass the LD_LIBRARY_PATH to the child process
so you migh try setting it explicitly or using a shell script like the
above.
-Steve W
joydip wrote:
> I am also getting the same error under RedHat. Any help. Regards, JS
> Jochem Prins wrote:
> Dear all, for some time i have been playing with UMN mapserver on a
> Fedora Core 4 i386 computer and manage to compile both ogr/gdal and
> UMN mapserver from source without Oracle Spatial. However for an
> assignment I got to make use of Oracle Spatial and shapefiles in
> combination with the mapserver. So far I manage to get everything I
> need to compile correctly without any weird errors. After
> installation of gdal/ogr and mapserver I attempt to test the
> mapserver by trying to query the mapserver by going to
> http://192.168.1.179/cgi-bin/mapserv. This gives me the 500 internal
> server error. When I view Apache's error log it says:
> /var/www/cgi-bin/mapserv: error while loading shared libraries:
> libclntsh.so.10.1: cannot open shared object file: No such file or
> directory Now I do know that this is related to some of the
> libraries that Oracle uses. I attempted several things to resolve
> this problem: - added the $ORACLE_HOME/lib to /etc/ld.so.conf and
> tried reloading by issueing ldconfig - added $ORACLE_HOME and
> $LD_LIBRARY_PATH to Apache's configuration file http.conf - I also
> checked if the problem was user rights related, but that doesn't
> seem to be the problem. Currently I am stuck and would really
> appreciate any help on this matter. Jochem Prins -- GMX Produkte
> empfehlen und ganz einfach Geld verdienen! Satte Provisionen für GMX
> Partner: http://www.gmx.net/de/go/partner
> View this message in context: Re: oracle spatial and mapserver problem
> <http://www.nabble.com/oracle-spatial-and-mapserver-problem-tf1449985.html#a9883537>
> Sent from the Mapserver - User mailing list archive
> <http://www.nabble.com/Mapserver---User-f1215.html> at Nabble.com.
