Possible MapServer development work
Mike Saunt
mikesaunt at GMAIL.COM
Tue Apr 10 07:10:37 EDT 2007
Thanks Richard
The highlighting now works a treat - I used an Expression in the end i.e.
qstring=(([UPRN] = 100061562714) OR ([UPRN] = 100061561248))
The only other thing I would love to do via the straight CGI is to be able
to specify a negativeTOLERANCE. Bascially I have some land parcels
(Polygons) that have planning applications (Polygons) over teh top. I want
the user to be able to select one or more Land Parcels (done above) and then
only find the Planning Applications that Intersect but don't BUTT onto as
they would come from a different property. The easiest way I thought of was
to have a negative tolerance of say 10cm or so but MapServer doesn't seem to
like negative TOLERANCES.
Any thoughts?
Cheers
mike
On 04/04/07, Richard Greenwood <richard.greenwood at gmail.com> wrote:
> On 4/3/07, Mike Saunt <mikesaunt at gmail.com> wrote:
> > I want a user to be able to interactively from multiple clicks on a map
> to
> > select features and then they can issue a query taking all selected
> features
> > and doing feature intersect queries against multiple other
> layers. Pretty
> > simple!
> You could do an asynchronous call to mapserv for each click and get
> the each feature ID back, and store it in a JavaScrit array.
> > I'm fine with writing wrapper code to allow the user to select a feature
> at
> > a point - MODE=QUERY - and then find and store the feature id's for
> > subsequent calls to the CGI
> > Is there a way to be able to pass multiple feature id's to MapServer to
> > highlight as selected in a maps?
> Yes, with mode=itemnquery
> Then in the same fashion can I pass
> > multiple feature id's (acting as the selection again) to then be used in
> a
> > NQUERY to find which features from other layers intersect.
> If I was doing it, and if I could use postgis, I would pass the
> parameters to a php page, run the query in postgis, get the feature
> IDs back, and then do another itemnquery with mapserv to graphically
> render it. This would not require mapscript, but would require php or
> some other server-side language that can connect to postgis.
> Rich
> Richard Greenwood
> www.greenwoodmap.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070410/812c8a8d/attachment.html
