projection time loss
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Fri Apr 13 02:10:46 EDT 2007
Why not to make a fast test by using your own data? Adjust your map file (or make a copy) so that the shapefiles are served first in the native projection of the data, and then in some other projection. If you have more interest you can tune for example JMeter to send a few thousand requests for both setups. This should give you some usable information.
Regards,
-Jukka Rahkonen-
-----Original Message-----
From: UMN MapServer Users List on behalf of Kevin Flanders
Sent: Fri 13.4.2007 0:15
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] projection time loss
I have several annotation shapefiles with several thousand labels each that
I need to either project on-the-fly or pre-process and project beforehand.
Would anyone care to comment on the performance hit this level of projection
on the fly might have on my Mapserver application..
Kevin
