Problem with map file serving WMS - tiff
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Mon Apr 16 04:08:49 EDT 2007
I've had the most luck with using absolute paths in tileindexes.
How did you generate your tileindex? If you generate it from the root of
your drive you should get absolute paths.
So:
cd \
for /r %i in (*.tif) do gdaltindex mytileindex.shp %i
Alternatively, you can try and set SHAPEPATH to
/ms4w/apps/chameleon/samples/data/topo/
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Steven De Vriendt <gisaalter at gmail.com>
Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Cc: MAPSERVER-USERS at lists.umn.edu
Onderwerp: Re: [UMN_MAPSERVER-USERS] Problem with map file serving WMS -
tiff
Datum: 16/04/07 06:01
> This is what's in the shpindex.dbf file
> location
> t136z.tif
> t136n.tif
> t137z.tif
> t137n.tif
> It doesn't mention any relative or absolute paths, just the names of
> my tif files...
> On 4/16/07, Bart van den Eijnden (OSGIS) <bartvde at osgis.nl> wrote:
> > What kind of values are in the location column of your tileindex dbf?
Are
> > these relative or absolute paths?
> > Best regards,
> > Bart
> > http://www.osgis.nl
> > Van: Steven De Vriendt <gisaalter at GMAIL.COM>
> > Naar: MAPSERVER-USERS at LISTS.UMN.EDU
<MAPSERVER-USERS at LISTS.UMN.EDU>
> > Onderwerp: [UMN_MAPSERVER-USERS] Problem with map file serving WMS -
tiff
> > Datum: 16/04/07 05:45
> > > Below is my map-file for serving a tiff file using mapserver
> > WMS-capabilities.
> > > Yet, I'm unsuccesfull finding out why it doesn't work.
> > > Can someone have a look at it and correct it where I've gone
wrong ?
> > > Thanks !
> > > MAP
> > > NAME TIFF_TEST
> > > STATUS ON
> > > SIZE 500 500
> > > SYMBOLSET ../etc/symbols.sym
> > > EXTENT 77336.359625 189988.500250 90937.297125 201812.968625
> > > UNITS METERS
> > > IMAGECOLOR 255 255 255
> > > FONTSET ../etc/fonts.txt
> > > TRANSPARENT FALSE
> > > WEB
> > > IMAGEPATH
&quot;/ms4w/apps/chameleon/samples/data/topo&quot;
> > > IMAGEURL &quot;/ms_tmp/&quot;
> > > METADATA
> > > &quot;wms_abstract&quot; &quot;Demo for
Geotiff&quot;
> > > &quot;wms_title&quot; &quot;WMS Demo
Server&quot;
> > > &quot;wms_onlineresource&quot;
&quot;http://0.0.0.0:8888/cgi-bin/mapserv.exe?map=/ms4w/apps/chameleon/samples/map/wmsserver_tiff.map&amp;&quot;
> > > &quot;wms_srs&quot; &quot;EPSG:31300&quot;
> > > END
> > > END
> > > OUTPUTFORMAT
> > > NAME GEOTIFF
> > > DRIVER &quot;GDAL/GTiff&quot;
> > > MIMETYPE &quot;image/tiff&quot;
> > > IMAGEMODE &quot;PC256&quot;
> > > EXTENSION &quot;tif&quot;
> > > END
> > > PROJECTION
> > > &quot;init=epsg:31300&quot;
> > > END
> > > LAYER
> > > NAME &quot;hillshade_rough&quot;
> > > TILEINDEX
&quot;/ms4w/apps/chameleon/samples/data/topo/shpindex.shp&quot;
> > > TILEITEM &quot;location&quot;
> > > TYPE RASTER
> > > STATUS ON
> > > # display layer only in map scales of 100000 and smaller,
means
> > > scale values &gt; 100000
> > > MINSCALE 100000
> > > METADATA
> > > &quot;WMS_TITLE&quot;
&quot;topokaarten&quot;
> > > &quot;WMS_ABSTRACT&quot;
&quot;agiv vlaanderen&quot;
> > > &quot;WMS_SRS&quot;
> > > END
> > > PROJECTION
> > > END
> > > END
