WFS Filter Oracle
Sture Dingsøyr
candalt at ONLINE.NO
Tue Apr 24 15:26:57 PDT 2007
Hi again
Thanx for answer :-)
I've tested again with excluding the "matchCase='false'" property in my "PropertyIsLike" search, and now "like" is used in my SQL statement as you say Bart, and also the WFS filter is working.
But this leads me to another question: will there be added support for the "matchCase='false'" parameter when using Oracle?
Cheers
Sture
There is ticket on this : http://trac.osgeo.org/mapserver/ticket/2075. I have fixed the ilike to be only done for postgis layers. I will wait for Sture answer to see if something has to be done for the escape statement.
Later,
Bart van den Eijnden (OSGIS) wrote:
> Hi Sture,
> if you leave out matchCase='false' in your filter ilike will turn into like.
> But you should file a bug about this, since ilike is for PostgreSQL.
> But at least you've got a workaround for now.
> I believe there is nothing wrong with escape '!', it should be there
> in case someone wants to escape a character in the search string. Does
> it not run in sqlplus? If so, what error do you get?
> Best regards,
> Bart
> Hello
> I've been testing ORACLE 10g Locator and Mapserver. There seem to be
> an issue when using WFS "PropertyIsLike" filter on an ORACLE 10g Locator layer.
> My WFS URL is like this:
> http://test/cgi-bin/mapserv.exe?map=wfs.map&SERVICE=WFS&VERSION=1.0.0&
> REQUEST=getfeature&MAXFEATURES=100&TYPENAME=layer_20&FILTER=<Filter><P
> ropertyIsLike wildcard='*' singleChar='.' escape='!'
> matchCase='false'><PropertyName>KOMMUNE</PropertyName><Literal>*123456
> *</Literal></PropertyIsLike></Filter>
> Mapserver the produces this SQL (based on WFS filter):
> SELECT ID, GEOM FROM (SELECT * FROM V_BE) WHERE KOMMUNE ilike '123456'
> escape '!' AND SDO_FILTER( GEOM, MDSYS.SDO_GEOMETRY(2003, 32632,
> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-269
> 32.706,6387567.41,1637291.63,8050226.99)
> ),'querytype=window') = 'TRUE'
> In the SQL there are some errors:
> "ilike '123456'" should be "like '123456'"
> escape '!' should not be present at all
> Could this be a bug or is there something wrong with my WFS filter URL?
> Cheers!
> Sture
> OSGIS, Open Source GIS
> http://www.osgis.nl
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
More information about the MapServer-users
