EPSG code of 32618 for WGS 84 / UTM zone 18N
John Mitchell
mitchelljj98 at GMAIL.COM
Wed Apr 25 11:51:34 EDT 2007
I have the listed the gdalinfo listing of an erdas imagine file below and
notice that it does not have a EPSG code within it. I need this EPSG code
if I want to reproject within gdalwarp or for on the fly projection within
mapserver. Based the gdalinfo listing I searched within the epsg file and
found the following code and definition:
# WGS 84 / UTM zone 18N
<32618> +proj=utm +zone=18 +ellps=WGS84 +datum=WGS84 +units=m +no_defs <>
Does the above EPSG code of 32618 make sense for the below gdalinfo listing?
Thanks,
John J . Mitchell
Driver: HFA/Erdas Imagine Images (.img)
Size is 13940, 33191
Coordinate System is:
PROJCS["UTM Zone 18, Northern Hemisphere",
GEOGCS["WGS_1984",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016],
TOWGS84[0,0,0,0,0,0,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-75],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
Origin = (638992.500000000000000,221212.500000000000000)
Pixel Size = (5.000000000000000,-5.000000000000000)
Corner Coordinates:
Upper Left ( 638992.500, 221212.500) ( 73d45'0.91"W, 2d 0'3.21"N)
Lower Left ( 638992.500, 55257.500) ( 73d45'3.46"W, 0d29'59.32"N)
Upper Right ( 708692.500, 221212.500) ( 73d 7'25.44"W, 2d 0'1.05"N)
Lower Right ( 708692.500, 55257.500) ( 73d 7'29.28"W, 0d29'58.78"N)
Center ( 673842.500, 138235.000) ( 73d26'15.17"W, 1d15'0.67"N)
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070425/8aaf41a3/attachment.html
