referencing location field files within shapefile within the same directory of the shapefile
John Mitchell
mitchelljj98 at GMAIL.COM
Thu Apr 26 07:38:37 PDT 2007
I ran gdaltindex referencing location field within shapefile within the same
directory of the shapefile (i.e. gdaltindex.exe shapefile.shp *.tif) instead
of including the full path (i.e. gdaltindex.exe c:\foldername\shapefile.shp
c:\foldername\*.tif). I found mapserver only displays (see layer below)
when the location field within the shape file has the full path to the
raster file, and does not display when location field only has the filename
even when the file is in the same folder as the shape file.
LAYER
# name of layer
NAME ElPaso_64Resolution
GROUP "gv:supplier_nga"
# what type of data is this?
TYPE RASTER
# always returned with interface
STATUS ON
TILEINDEX
"G:\NGA_Data\El_Paso_All_Units\converted_1176381368109\64Resolution.shp"
TILEITEM "Location"
OFFSITE 0 0 0
MINSCALE 64000
#MAXSCALE 4000
END
John J. Mitchell
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070426/8b998a0f/attachment.htm>
More information about the MapServer-users
