Symbology Questions
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Sun Apr 29 10:39:42 EDT 2007
OK, I have sort of figured out the disappearing fills. It seems to be
related to using:
OUTPUTFORMAT
NAME PNG8
DRIVER "GD/PNG"
EXTENSION "png"
MIMETYPE "image/png"
IMAGEMODE RGBA
TRANSPARENT ON
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
END
If I change to just a "png" image instead of "PNG8" the fills will show.
I'm not sure what the story is with that.
-Steve
Stephen Woodbridge wrote:
> On further investigation, it looks like the fill on the truetype symbol
> is white but the symbol is drawn in black, the requested color. The
> layer looks like:
> # Building
> LAYER
> NAME "buildin_p"
> GROUP "CO"
> STATUS DEFAULT
> MAXSCALE 100100
> TILEINDEX "tindex-50k"
> DATA "buildin_p"
> TYPE POINT
> CLASSITEM "ATC"
> CLASS
> END
> CLASS
> EXPRESSION "177" # Industrial building
> STYLE
> SYMBOL "building"
> SIZE 15
> ANGLEITEM "ANGLE"
> COLOR 0 0 0
> END
> END
> END
> -Steve
>> Hi all,
>> I have some question on symbology that are not address by the current
>> documentation. I'm using mapserver 4.10.1
>> 1) I have truetype font with symbols in it. Some of the symbols I can
>> trying to use show nicely in Windows Character Map as a solid filled
>> pictograph, but when I create a mapserver symbol it is just an outline.
>> SYMBOL
>> NAME "building"
>> TYPE TRUETYPE
>> FONT "cartogra"
>> CHARACTER "F"
>> FILLED TRUE
>> END
>> 2) I need to make a dashed line with some additional symbols along it,
>> like:
>> Where the (.) is a circle with a dot. I have a truetype symbol for the
>> (.), but the (.) needs to fall in what would otherwise be a gap. So I
>> am trying something like this:
>> SYMBOL
>> NAME "a_cable_dot"
>> TYPE TRUETYPE
>> FONT "cartogra"
>> CHARACTER "J"
>> GAP 100
>> END
>> SYMBOL
>> NAME "a_cable_dash"
>> TYPE ELLIPSE
>> POINTS 1 1 END
>> FILLED TRUE
>> STYLE 0 5 20 5 20 5 20 5 20 END
>> END
>> then overlaying the two of these with two styles.
>> Is there a better way of doing this?
>> How can I control the placement of the circle-dot.
>> Thanks,
>> -Steve W
