MapServer 5.0 Beta5 (via MS4W)- msQueryByPoint doesn't seem
to work
Mike Saunt
mikesaunt at GMAIL.COM
Fri Aug 24 06:03:41 EDT 2007
Hi Howard (et all)
Apologies for the delay in coming back to you - holiday season!
This query issue is still apparent with Beta 5 of MS4W - it will take me a
little time to setup a map file and test data for this.
Question is - is there test data available that I can use to highlight the
problem below back to MapServer developers ?
Many thanks
Mike
On 13/08/07, Howard Butler <hobu.inc at gmail.com> wrote:
> The process is described here: http://trac.osgeo.org/mapserver/wiki
> On Aug 13, 2007, at 10:52 AM, Mike Saunt wrote:
> > Thanks Howard
> > How / where do I log bugs...?
> > Cheers
> > Mike
> > On 13/08/07, Howard Butler <hobu.inc at gmail.com > wrote:Mike,
> > We'll need bugs filed for both of these issues. The more condensed
> > detail you can provide, the better. I have no idea on that threading
> > one...
> > Howard
> > On Aug 13, 2007, at 5:09 AM, Mike Saunt wrote:
> > > Hi Howard
> > > All standard flat files (actually cache from ArcSDE using OGR due
> > > to the previous fastcgi / arcsde stability issues)
> > > They are all either MapInfo or Shape files
> > > Would you like a sample .map file with data?
> > > Also FYI - the beta's had an issue with a 'global_thread_end' which
> > > although the map would be generated in around 1 second the process
> > > stayed resident for 8 seconds - I'm on xp 64bit dev machine but it
> > > happened on a 32 bit xp machine also. I guess this was related to
> > > the libmysql.dll (I'm using the MS4W dll's from the cgi-bin
> > > directory but loaded into IIS) so I replaced with another version
> > > off the web. Do you think this would be related?
> > > I could get it rebuilt from Source but oftern try to avoid this as
> > > the MS4W has done me proud before!
> > > Could you let me know your thoughts?
> > > Cheers
> > > Mike
> > > Which driver are you using? IIRC, you had used the ArcSDE driver
> > > some in the past. If you still are, could you please file a ticket
> > > with some detailed examples?
> > > Howard
> > > On Aug 12, 2007, at 4:26 PM, Mike Saunt wrote:
> > > > Hi All
> > > > Not sure if this should really go to the MapServer Development
> > list
> > > > - although I'm not a member of that list anyway.
> > > > Has anyone else had an issue with nquery / msQueryByPoint /
> > > > msQueryByRect with Beta3 of MapServer 5.0?
> > > > This query against a single layers and we have others that Query
> > > > against multiple in one go.
> > > > http://localhost/mapserver5.0/mapserv.exe?map=D:/Maps/BaNES/
> > > > _MapServerConfig/BaNES.map&mode=nquery&mapsize=987
> > > > +386&img.x=511&img.y=87&imgext=328010.483766+145811.5
> > +403519.516234
> > +175295.25&layers=CivicAmenitySites&map_CivicAmenitySites_tolerance=10
> > > > &map_CivicAmenitySites_template=_MapServerTemplates/
> > > > CivicAmenitySites_fields.xml
> > > > All map rendering is working great (love the AGG renderer!) but
> > > > none of our spatial query (NQUERY etc) strings are working. I
> > > > can't see anything from the Migration Guide as to what could be
> > > > wrong...
> > > > Any help appreciated or a pointer to the MapServer dev list...
> > > > Cheers
> > > > Mike
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070824/cfaf182e/attachment.html
