MapScript C# Memory Corruption Problem (MapServer 4.10)
Tamas Szekeres
szekerest at GMAIL.COM
Thu Feb 1 16:47:00 EST 2007
Hi Hong,
Are you still getting the problem at the same function or the location
may change in a random fashion? Do you have a stacktrace on it?
At the moment I can think of 3 issues the memory problem might be related to.
1. Usage of different CRT heaps / using different dll versions
You should make sure (once again) that only 1 version of the CRT dll
is used in the dependency tree of mapscript.dll. In this case
msvcr71.dll would be the expected version. If the same dll is
referenced from multiple dll-s make sure that the references point to
the same location. Make sure that the same dll has been loaded as you
have compiled against.
Kicking off the unused dependencies are also a good practice. (May be
you have possibly done it)
2. Early garbage collection
Ensure that the lifespan of the child references (eg. layerObj) are
not falling outside of the lifespan of the root object (eg. mapObj).
Here is an example may cause potential problems:
parentObj parent = new parentObj();
childObj child = parent.getChildObj();
// at this point there's no more references to 'parent' so it might be
garbage collected
child.OperateOnChild(); // will cause access violation
So as to keep the parent alive until a certain point you might use
GC.KeepAlive() as.
GC.KeepAlive(parent);
will prevent from garbage collecting the parent until the
OperateOnChild() returns. Try to add GC.KeepAlive()
at the end of the function.
3. Multithreading issues.
To properly isolate this issue a global lock should be added when
invoking the mapscript code (practically at mapscript.dll). I will
consider how it can be done easily. Until then you can make a test
against the builtin shape or the posgis driver to see whether the
problem is SDE related or not.
Since you have compiled with MSVC71 mapscript.dll might run with
MS.NET FW 1.1 but it should not be a problem, definitely.
Best Regards,
Tamas
2007/2/1, Hong <ljfong at sdf.lonestar.org>:
> An update for my progress:
> After calling clone() before calling draw() of mapObj, MapServer became more
> stable, but under heavier load (many more dynamic layers and config), the
> memory corruption still happened.
> The strange solution I had found was to compile MapServer using Visual Studio
> 2003 instead of 2005. After doing so, MapServer no longer suffered memory
> corruption. For some reason, the binary produced from VS2003 running under
> .NET 2.0 did not have any memory management problem. This was done with the
> mapObj still being maintained through session.
> After a lot of brainstorming over this, I have come to the conjecture that the
> garbage collector in the .NET framework might have been the culprit of the
> memory corruption. Since MapServer internal objects are managed internally via
> PInvoke, they are unmanaged as far as the garbage collector is concerned.
> Somehow between ASP.NET page postbacks, the garbage collector came in and
> invalidated the references unmanaged objects prematurely, as they are not
> referenced by any managed object. Now, objects compiled for .NET 1.1 (vs 2003)
> are somehow treated differently by the garbage collector of .NET 2.0. I don't
> know the exact mechanism. There are ways to control the garbage collector,
> however I would rather not explore them.
> I would like to hear any other thoughts/comments.
> Hong
> On Mon, Jan 22, 2007 at 10:39:38PM -0700, Hong wrote:
> > I have reopened the bug report.
> > On Mon, Jan 22, 2007 at 11:12:39PM +0100, Tamas Szekeres wrote:
> > > 2007/1/22, Hong <ljfong at sdf.lonestar.org>:
> > > >Now instead of using the mapObj stored in the session, I perform a clone()
> > > >on the mapObj from the session, and use the clone to perform draw(). So
> > > >far, I
> > > >have not seen any crash after doing this. The only problem I observed was
> > > >that
> > > >the symbol transparencies was messed up after subsequent clone + draw.
> > > >Maybe
> > > >the clone is not perfect, I'm not sure.
> > > That seems strange. You should describe the problem in more detail and
> > > reopen the following bug then:
> > > http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=931
> > > Please attach the corresponding mapfile, the symbol definition file
> > > and the symbol image to this bug.
> > > Best Regards,
> > > Tamas
