Mapserver & SDE 9.1 performance
Brock Anderson
banders at REFRACTIONS.NET
Thu Feb 1 18:34:07 EST 2007
Emmanuel,
I have no idea why SDE is sending two responses, but...
are you using FastCGI? I've found the ArcSDE connection overhead can
take 1-2 seconds (per layer, per request). Mapserver can use connection
pooling to ease that problem, but only if you're running with FastCGI.
http://mapserver.gis.umn.edu/docs/howto/fastcgi
Brock
Emmanuel BELO wrote:
> Dear list,
> we have installed Mapserver 4.10 compiled with SDE 9.1 support on a
> windows OS (IIS and PHP5 ISAPI). The application is working, but with
> poor performances: 9 to 64 times slower performances when rendering
> vector data from SDE than from an indexed shapefile exported from SDE
> (same dataset).
> We investigated and found:
> - mapserver renders data as fast with SDE than with SHP data, the
> difference is made between mapserver query to SDE and the end of SDE
> response.
> - after a mapserver query (for a point layer, without queries nor
> labels) SDE sends sequentially two responses with nearly the same size.
> In our case, each response is about 3 sec.
> So, we have two questions:
> - first: why does SDE answers twice?
> - is somebody using Mapserver/SDE with good performances?
> Best regards,
> Emmanuel BELO
