non-square shapefiles and tileindex
Ara T Howard
ara.t.howard at NOAA.GOV
Sat Feb 3 10:54:20 EST 2007
On Fri, 2 Feb 2007, Brent Fraser wrote:
> If your goal is to not write any "null" pixels (e.g. black) from an input
> image into the output image, you can use the OFFSITE layer setting in the
> R,G,B values that are to be considered "null" and should not be rendered
> into the output image. And there may be some more sophisticated techniques
> using the PROCESSING object in the layer definition.
so, i just tried that with the mapfile i showed you. i tried both
OFFSITE 255 255 255
and
OFFSITE 255
both result in totally blank output from mapserver for the request i posted?
thoughts?
-a
we can deny everything, except that we have the possibility of being better.
simply reflect on that.
- the dalai lama
