feature-id in getfeatureinfo requests
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Mon Feb 5 10:30:13 EST 2007
Ah right, and how about:
gml_featureid "oid"
If this does not work, can you post your DATA statement?
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Richard Duivenvoorde <rdmailings at duif.net>
Naar: Bart van den Eijnden OSGIS <bartvde at OSGIS.NL>,
MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
Onderwerp: Re: [UMN_MAPSERVER-USERS] feature-id in getfeatureinfo requests
Datum: 05/02/07 13:25
> Hi Bart,
> Thanks for the quick response :-)
> I tried that already, but in the text output, I see ALL columns of the
> table (though not the 'oid' as a normal 'attribute') in the output. But
> there is this line:
> 'Feature 17246'
> Which IS the oid/feature_id....
> In the gml I also receive ALL columns in the output, but NO reference to
> this 17246 oid/feature_id/id...
> I tried all these:
> "ows_include_items" "all"
> "gml_include_items" "all"
> "wms_include_items" "all"
> is the oid-column not an official attribute column or something like that?
> Richard
> Bart van den Eijnden (OSGIS) wrote:
> > Hi Richard,
> > you need to add
> > GML_INCLUDE_ITEMS "all"
> > to your LAYER's METADATA section.
> > Best regards,
> > Bart
> > http://www.osgis.nl
> > Van: Richard Duivenvoorde <rdmailings at DUIF.NET>
> > Naar: MAPSERVER-USERS at LISTS.UMN.EDU
> > Onderwerp: [UMN_MAPSERVER-USERS] feature-id in getfeatureinfo
requests
> > Datum: 05/02/07 13:01
> >> Hi All,
> >> busy using getfeatureinfo from a postgresql/postgis layer.
> >> Mapserver version 4.8.3 (...)
> >> Postgresql-table is a point table and has a oid column (create
script
> >> with 'WITH OIDS').
> >> I managed to get the getfeatureinfo up and running, but stumble
upon the
> >> missing (feature)-id in the gml output:
> >> When I do an info format of 'text/plain' I'll receive something
like:
> >> GetFeatureInfo results:
> >> Layer 'testpoints'
> >> Feature 17246:
> >> bla = 'zyz'
> >> foo= ''
> >> but when i ask for 'application/vnd.ogc.gml' as info format I
receive
> >> gml without the feature-id (not even as a normal 'oid'
property??):
> >> &lt;?xml version=&quot;1.0&quot;
encoding=&quot;ISO-8859-1&quot;?&gt;
> >> &lt;msGMLOutput
> >> xmlns:gml=&quot;http://www.opengis.net/gml&quot;
> >> xmlns:xlink=&quot;http://www.w3.org/1999/xlink&quot;
xmlns:xsi=&quot;http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
> >> &lt;testpoints_layer&gt;
> >> &lt;testpoints_feature&gt;
> >> &lt;gml:boundedBy&gt;
> >> &lt;gml:Box
srsName=&quot;EPSG:28992&quot;&gt;
> >> &lt;gml:coordinates&gt;67349.250981,549785.660401
> >> 67349.250981,549785.660401&lt;/gml:coordinates&gt;
> >> &lt;/gml:Box&gt;
> >> &lt;/gml:boundedBy&gt;
> >> &lt;bla&gt;zyz&lt;/bla&gt;
> >> &lt;foo&gt;&lt;/foo&gt;
> >> &lt;/testpoints_feature&gt;
> >> &lt;/testpoints_layer&gt;
> >> &lt;/msGMLOutput&gt;
> >> Am I missing some metadata property in my mapfile? I would expect
either
> >> a feature-id attribute in the testpoints_feature element, OR
oid-element
> >> as child of the testpoints_feature element.
> >> TIA,
> >> Richard
