configure crt1.o error on PPC64 RHEL
Doug B
ummmmm22 at GMAIL.COM
Mon Feb 5 12:26:52 EST 2007
Setting CFLAGS environment variable seems to have worked, FWIW. If
there's a safer mechanism, I'd be happy to use that too.
On 2/5/07, Doug B <ummmmm22 at gmail.com> wrote:
> Hmmm - gcc -m64 does not report that error. What's the best way to
> use that flag in configure?
> On 2/2/07, Doug B <ummmmm22 at gmail.com> wrote:
> > You're right. Exact same error. Guess I need to ask elsewhere since
> > I've now installed the rpms that contain gcc as well as the library in
> > question. Thanks.
> > On 2/2/07, ara.t.howard at noaa.gov <ara.t.howard at noaa.gov> wrote:
> > > On Fri, 2 Feb 2007, Doug B wrote:
> > > > No other advice or ideas on what's misconfigured?
> > > http://www.google.com/search?hl=en&q=crt1.o%3A+No+such+file%3A+No+such+file+or+directory&btnG=Google+Search
> > > basically you're operating system is incomplete with respect to
> > > development/compilation.
> > > does this even work for you:
> > > harp:~ > echo "main(){}" > a.c && gcc a.c && a.out && echo success
> > > success
> > > i assume not. once you've got a working compiler tool-chain you should have
> > > no problem. perhaps you've got some sort of desktop install vs. a development
> > > version of rhe?
> > > regards.
> > > -a
> > > we can deny everything, except that we have the possibility of being better.
> > > simply reflect on that.
> > > - the dalai lama
