shpree error while loading shared libraries
P Kishor
punkish at EIDESIS.ORG
Mon Feb 5 14:16:36 EST 2007
On 2/5/07, Howard Butler <hobu at iastate.edu> wrote:
> It appears that they linked it against the ArcSDE libraries. You
> will likely have to recompile yourself or acquire the SDE SDK .so
> files for ArcSDE 8.3.
Yes, so they did. Yet, everything else works (well, I should correct
that -- mapserv works fine via cgi, but the command line utils croak).
Question -- can I build shptree all by itself (in fact, I would like
to do that on my Macbook as well without having to build the entire
kitchen sink).
A related question -- it is correct to assume that indexes built on
one computer will work on another computer? So, if I index my shape
files on a 'doze computer and move it to Red Hat or Mac, will the
indexes work?
> At 12:43 PM 2/5/2007, P Kishor wrote:
> >I was trying to use shptree that someone else had built. I got the
> >following error.
> >/usr/src/mapserver-4.4.2/shptree: error while loading shared
> >libraries: libsde83.so: cannot open shared object file: No such file
> >or directory
> >How can I make this work? This is on Red Hat Advanced Server or some
> >such thing.
Puneet Kishor http://punkish.eidesis.org/
Nelson Inst. for Env. Studies, UW-Madison http://www.nelson.wisc.edu/
Open Source Geospatial Foundation http://www.osgeo.org/education/
collaborate, communicate, compete
