Problem in web template
Saif
kmsaif at YAHOO.COM
Tue Feb 6 23:14:07 EST 2007
I am a newbie in mapserver and have a problem in using web template
<html>
<head> <title> GIS Application </title> </head>
<body>
<form method =POST action = "/cgi-bin/mapserv">
<input type = "submit" value ="Click to Intialize">
<input type = "hidden" name ="map" value
= "/ms4w/apps/MyApplic/htdocs/WSLT.map">
<input type = "hidden" name ="mapext" value = "644939.974768
5571028.735107 777118.073090 5711137.519287">
<input type = "hidden" name ="zoomsize" size =2 value =2>
<input type="hidden" name="program" value="/cgi-bin/mapserv">
<input type="hidden" name="map_web_imageurl" value="/tmp/">
</form>
</body>
</html>
When I run the web page and tried "Click to Intialize", it showed me
"No page can not be displayed"
and in address bar I got this line
C:\cgi-bin\mapserv
When I tried mapserv.exe instead mapserv in action = "/cgi-bin/mapserv.exe",
it asked me to save or run the mapserv.exe. I have checked ms4w folders. I
have read and write permissons. Environemnt variables are ok. When I tried to
check mapserv at command prompt, it gave me
The script can only be used to decode from results and should be initiated as
a CGI process via a httpd server.
I tried mapserv -v as well and it showed me mapserv version 4.10.0
OUTPUT=GIF OUTPUT=GIF ....................................
in map file I have also described web template
# web Object
WEB
TEMPLATE "/ms4w/apps/MyApplic/templates/"
IMAGEPATH "/ms4w/apps/MyApplic/images/"
IMAGEURL "/tmp/"
LOG "/tmp/mapserver.log"
END
I am wondering if anybody can help me with this problem.
Thanks
