Big problems to set MS_Mapfile-Path
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Mon Feb 12 18:33:06 EST 2007
Hi There,
You might want to try to add something at the end of the url : something
like http://localhost/cgi-bin/mymaps.exe?ttt=1 and force the length of
the QUERY_STRING to be > 0.
Later,
Reinhard Keltermann wrote:
> Dear users,
> since a couple of time I`m trying desperately to set my MS_Mapfile-Path.
> I`m using Windows XP with ms4w 2.2.2.
> I change the httpd.conf in C:/ms4w/Apache/conf
> I write at the end:
> SetEnvIf Request_URI "/cgi-bin/mymaps.exe" MS_MAPFILE=/ms4w/my_directory/abcde.map
> Well, obviously the file "abcde.map" lies under C:/ms4w/my_directory/abcde.map
> I have copied the file "mapserv.exe" under C:/ms4w/Apache/cgi-bin and renamed the copy to
> "mymaps.exe".
> I have restarted the Apache server.
> But when I use the url:
> I always get the message: No query information to decode. QUERY_STRING is set, but empty.
> Why is the mapfile not parsed then????
> I have also checked out: SetEnvIf Request_URI "/cgi-bin/mymaps" MS_MAPFILE=/ms4w/my_directory/abcde.map
> but with the same result.
> To see if there is a mistake with the SetEnv-Command I have also written:
> SetEnv MS_ERRORFILE "/ms4w/tmp/ms_error.txt"
> If there is an error with the mapfile, the error occurs in c:/ms4w/tmp/ms_error.txt, so the SetEnv-Command works.
> Who can help please????????
> Thank you.
> Rich
> ______________________________________________________________________
> XXL-Speicher, PC-Virenschutz, Spartarife & mehr: Nur im WEB.DE Club!
> Jetzt gratis testen! http://freemail.web.de/home/landingpad/?mc=021130
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
