(chinese) unicode labeling with postgis db
Mario Basa
mario.basa at GMAIL.COM
Wed Feb 14 10:13:18 EST 2007
Hello Christian,
What I usually do if I have label encoding problems (w/c happens a lot
with japanese characters) is to create an annotation layer with an
inline feature and then test using different fonts or encoding
parameters. Something like this:
LAYER
NAME "Label Test"
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS 420 420 END
TEXT " Japanese_Characters_go_here "
END
CLASS
LABEL
TYPE TRUETYPE
ENCODING SJIS
FONT pgothic
SIZE 10
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 255
END
END
END
Also, the ENCODING parameter translates the label into UTF-8, so if
the label is in UTF-8 already, ENCODING shouldn't be necessary
anymore.
Regards,
Mario.
2007/2/14, Christian Sengstock <csengstock at gmail.com>:
> Hi list,
> i try to do labeling for chinese features but have some problems.
> I tried to make it the way i found in some docs in the internet and in
> the mail archive:
> - use a postgis unicode db
> - use unicode truetype fonts
> But unfourtunately its not working for now.
> I use a postgres/postgis dbms (PostgreSQL 8.0.9 POSTGIS 1.0.6) and
> mapserver 4.10.0 (ms4w package).
> My database is UNICODE encoded (imported with GB18030 client encoding).
> The unicode chars seem to be ok, i can use these chinese strings in my
> web application and they work.
> I have a point layer which i render with UMN mapserver.
> Now i tried to render the points like this...
> LAYER
> NAME 'poi'
> TYPE POINT
> CONNECTIONTYPE postgis
> CONNECTION '...'
> DATA 'geom FROM geo.poi'
> METADATA
> 'wms_title' 'poi'
> END
> STATUS ON
> TRANSPARENCY 100
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> END
> LABELITEM 'name'
> CLASS
> NAME poi
> STYLE
> SYMBOL 'circle'
> SIZE 3
> COLOR 255 150 150
> END
> LABEL
> ANTIALIAS true
> COLOR 255 255 255
> OUTLINECOLOR 0 0 0
> POSITION CC
> OFFSET 0 2
> BUFFER 2
> TYPE TRUETYPE
> FONT 'arialuni'
> ANGLE auto
> SIZE 8
> #ENCODING UTF-8 | UNICODE ???
> END
> END
> END
> where font 'arialuni' ist the microsoft arial unicode font:
> arialuni ARIALUNI.TTF
> If i use ENCODING UNICODE, its no labels at all.
> If i use ENCODING UTF-8 (or GB18030), its like i have no ENCODING attribute.
> Attached is a screenshot from the map.
> Maybe someone can help or can point me to a good doc?
> Thanx a lot,
> Chris
