ArcSDE Version Error
Fawcett, David
David.Fawcett at STATE.MN.US
Wed Feb 14 12:46:48 EST 2007
OK. With the below layer def, MapServer returns an image. This is
progress, the only issue is that none of the features in the SDE layer
show up.
LAYER
NAME testsde
STATUS DEFAULT
TYPE POINT
CONNECTION "myserver.pca.state.mn.us,port:5152,sde,uuuuu,ppppp"
CONNECTIONTYPE SDE
#PROCESSING "QUERYORDER=ATTRIBUTE"
DATA "WATER.WELLS,SHAPE,SDE.DEFAULT"
CLASS
STYLE
SYMBOL 'circle'
SIZE 15
COLOR 255 0 0
END
END
END
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Fawcett, David
Sent: Wednesday, February 14, 2007 10:45 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] ArcSDE Version Error
Below is the layer def. I changed the colon after 'port' to a comma per
the comments in the vector data access doc. This returned a different
error message:
msDrawMap(): Image handling error. Failed to draw layer named 'testsde'.
msSDELayerOpen(): SDE error. SE_connection_create(): Entry for SDE
instance not found in services file. (-102)
The port number is correct. I am running SDE 9.1 on Solaris.
LAYER
NAME testsde
STATUS DEFAULT
TYPE POINT
CONNECTION "myserver.pca.state.mn.us,port,5152,sde,uuuuu,ppppp"
CONNECTIONTYPE SDE
DATA "WATER.WELLS,SHAPE,DEFAULT"
TEMPLATE "selectcounty.html"
FOOTER "selectcountyfoot.html"
CLASS
COLOR 255 0 0
END
END
Behalf Of Howard Butler
Sent: Wednesday, February 14, 2007 9:22 AM
MapServer is connecting to SDE just fine, but I think you have your
DATA block specified incorrectly. SE_version_get_info is a function
queries SDE get the specific version of the layer you wish to connect
to. If you are using SDE in multiple-editor scenario, this is useful
for showing where the states of specific version of the layers are.
What do your CONNECTION and LAYER blocks look like (minus sensitive
info, of course)?
Howard
On Feb 14, 2007, at 8:54 AM, Fawcett, David wrote:
> I am trying to get a MapServer ArcSDE connection working. When I hit
> mapserv, I get the follwing errors: =20
> 'testsde'.
> msSDELayerOpen(): SDE error. SE_version_get_info(): Version not found.
> (-126)=20
> I didn't do the compile myself. Since I don't see any examples where
> the version is set in the map file, I am guessing that this error is
> showing up because the version was not properly set with the compile
> option '--with-sde-version=3D90'. =20
> Can anyone confirm (or refute) this? =20
> Thanks,=20
> David.
