PHP MapScript, ms_newMapObj error, Failed to open map file
Doug B
ummmmm22 at GMAIL.COM
Mon Feb 19 17:27:46 EST 2007
Thankyou! Ok, so the fact that an error precedes the one about
opening the .map file means that it's a problem inside the .map file.
Seems obvious in hindsight, but I was fixated on that "Failed to open"
message. Onto the next problem. Thanks again.
Doug
On 2/19/07, Daniel Morissette <dmorissette at mapgears.com> wrote:
> Doug B wrote:
> > [Mon Feb 19 14:14:57 2007] [error] [client 32.86.231.32] PHP Warning:
> > [MapServer Error]: getString(): Parsing error near (none):(line 109)
> > [Mon Feb 19 14:14:57 2007] [error] [client 32.86.231.32] in
> > /var/www/html/offender/map.php on line 75
> There is an error parsing the map file near keyword "none" (probably
> just before) around line 109 in the map file, probably related to
> something that changed in the mapfile parser between MapServer 4.2 and 4.8.
> My guess is that MapServer is expecting a string but it's finding the
> keyword NONE. You may need to add quotes around the "none".
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
