mapserver not compiled with postgis support
Doug B
ummmmm22 at GMAIL.COM
Tue Feb 20 10:36:24 EST 2007
[Tue Feb 20 09:29:25 2007] [error] [client 32.86.231.32] PHP Warning:
[MapServer Error]: msDrawMap(): Failed to draw layer named
'Offender_PostGIS'.
[Tue Feb 20 09:29:25 2007] [error] [client 32.86.231.32] in
/var/www/html/offender/map.php on line 87
[MapServer Error]: msPOSTGISLayerOpen(): msPOSTGISLayerOpen called but
unimplemented! (mapserver not compiled with postgis support)
[Tue Feb 20 09:29:25 2007] [error] [client 32.86.231.32] PHP Fatal
error: Object expected as argument. in /var/www/html/offender/map.php
on line 106
I did configure with --with-postgis=<path to pg_config> and mapserv -v reports:
MapServer version 4.8.4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=FREETYPE INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
INPUT=SHAPEFILE
Would I get a different error if postgis support was actually included
but the layer or the postgis configuration wasn't correct?
Thanks again for the help.
Doug
