mapserver not compiled with postgis support
Paul Ramsey
pramsey at REFRACTIONS.NET
Tue Feb 20 11:22:45 EST 2007
Doug,
Note that the error is "PHP Warning", so your mapserv executable doesn't
enter into the equation. What you *do* have is a php_mapscript.so which
doesn't have PostGIS support compiled in somewhere in your installation.
Pau
Doug B wrote:
> Thought about that, but "find" only finds 2 copies, one in the src
> directory from which I compiled, and one in /usr/local/bin where
> install-force copied it. (And both are identical in size, which
> confirms for me that they're the same file.)
> As far as other libraries, I have no idea which they'd be. As far as
> I know, it's only the MapServer compile which uses it.
> Doug
> On 2/20/07, David Potts <dave.potts at pinan.co.uk> wrote:
>> Is it possible that you have more than one version of mapserver on your
>> system ? or that any library that your using does not have postgis
>> compiled in?
>> D.
>> > [Tue Feb 20 09:29:25 2007] [error] [client 32.86.231.32] PHP Warning:
>> > [MapServer Error]: msDrawMap(): Failed to draw layer named
>> > 'Offender_PostGIS'.
>> > [Tue Feb 20 09:29:25 2007] [error] [client 32.86.231.32] in
>> > /var/www/html/offender/map.php on line 87
>> > [MapServer Error]: msPOSTGISLayerOpen(): msPOSTGISLayerOpen called but
>> > unimplemented! (mapserver not compiled with postgis support)
>> > [Tue Feb 20 09:29:25 2007] [error] [client 32.86.231.32] PHP Fatal
>> > error: Object expected as argument. in /var/www/html/offender/map.php
>> > on line 106
>> > I did configure with --with-postgis=<path to pg_config> and mapserv -v
>> > reports:
>> > MapServer version 4.8.4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> > OUTPUT=SVG SUPPORTS=FREETYPE INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
>> > INPUT=SHAPEFILE
>> > Would I get a different error if postgis support was actually included
>> > but the layer or the postgis configuration wasn't correct?
>> > Thanks again for the help.
>> > Doug
Paul Ramsey
Refractions Research
http://www.refractions.net
pramsey at refractions.net
Phone: 250-383-3022
Cell: 250-885-0632
