WMS/WFS and (yearly) time-dependent data
Stefan Schwarzer
stefan.schwarzer at GRID.UNEP.CH
Thu Feb 22 09:34:40 EST 2007
I am not (or better: hardly) working with raster data. All vector
data. National statistics for the whole world, like population
density, gdp, forest cover etc.
So, the each one of the 1000 or so (postgres) tables looks like this:
id 1970 1971 .... 2006
1 23.1 35.4 .... 45.6
2 12.3 10.9 .... 4.23
249 .....
and each id is then linked to another (postgis) table with the
country names and the geometry.
> How is your data structured in postgis ? There is an example in
> the how using a postgis layer with a time field :
> http://mapserver.gis.umn.edu/docs/howto/wms_time_support/#example-
> of-wms-t-with-postgis-tile-index-for-raster-imagery
>>> If your are serving layers as wms you could do soemthing like this :
>>> - define a tileindex layer example:
>>> LAYER
>>> NAME "mylayer"
>>> STATUS ON
>>> # TYPE POLYGON
>>> TYPE RASTER
>>> METADATA
>>> "DESCRIPTION" "mylayer"
>>> "wms_title" "mylayer"
>>> "wms_timeitem" "time"
>>> "wms_timeextent" "1970/2006"
>>> "WMS_SRS" "epsg:4326"
>>> END
>>> SIZEUNITS PIXELS
>>> TILEINDEX "tile_file"
>>> TILEITEM "location"
>>> - have a tile index that has at least 2 field (localtion for the
>>> files, and a time field) :
>>> location time
>>> mypath/myfile 2005
>>> - doing a request of Getmap : something like
>>> GetMap&Version=1.1.1&LAYERS=mylayer&Time=2005
>>> Not sure if that fits your model.
>>> Best Regards
>>> Bart van den Eijnden (OSGIS) wrote:
>>>> I think you should be looking at tile-indexing for the TIME
>>>> dimension. A
>>>> field in the dbf of the tile-index will probably state which
>>>> shapefile
>>>> Mapserver needs to open for that specific year (and that
>>>> specific theme).
>>>> I believe the WCS howto has some information on how to do this,
>>>> but I have
>>>> no experience with this whatsoever:
>>>> http://mapserver.gis.umn.edu/docs/howto/WCSServerFormatHowTo
>>>> Best regards,
>>>> Bart
>>>> OSGIS, Open Source GIS
>>>> http://www.osgis.nl
>>>> --------- Oorspronkelijk bericht --------
>>>> Van: Stefan Schwarzer <stefan.schwarzer at GRID.UNEP.CH>
>>>> Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
>>>> Onderwerp: [UMN_MAPSERVER-USERS] WMS/WFS and (yearly) time-
>>>> dependent data
>>>> Datum: 21/02/07 09:44
>>>>> Hi,
>>>>> i read in a document ( http://mapserver.gis.umn.edu/docs/howto/
>>>>> wms_time_support/view ) that there is a WMS/WFS-parameter one
>>>>> can specify for time dependent data. I am dealing mostly with
>>>>> statistical data sets, which are covering a period of 1970 to
>>>>> 2006. So it should be something like TIME=2004 to query a
>>>>> specific year.
>>>>> For each variable and year there is a five-classes breakup.
>>>>> It is not clear to me how I should set-up my map file. I guess,
>>>>> I could on one hand just have 36 layers (for each year a
>>>>> layer) - then I wouldn't need the TIME parameter. But as I
>>>>> have some 1000 files to deal with, my map file would get
>>>>> pretty long...
>>>>> The other solution would be to have some kind of grouping
>>>>> classes, so that all my years would fit into one layer, but
>>>>> into 36 classes.
>>>>> Or is there any kind of more "dynamic" solution?
>>>>> Thanks for any suggestions!
