OracleSpatial getFeatureInfo problem against unique column
containing text
Sebastian Schmitz
sebastian.schmitz at WHEREGROUP.COM
Fri Feb 23 06:34:39 EST 2007
Now what do I do?
Is this a restriction from Oracle-side or from MapServer?
MapServer I guess?
Cheers
Sebastian
Bart van den Eijnden (OSGIS) schrieb:
> No this is not possible.
> You need to use an integer for the unique column. It's a requirement.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Sebastian Schmitz <sebastian.schmitz at WHEREGROUP.COM>
> Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
> Onderwerp: [UMN_MAPSERVER-USERS] OracleSpatial getFeatureInfo problem
> against unique column containing text
> Datum: 23/02/07 08:33
>> Hi,
>> I have a view in Oracle Spatial 10gR2 with a unique Id, which is text.
>> MapServer draws the map OK using oraclespatial CONNECTIONTYPE.
>> However, MapServer is unable to serve a getFeatureInfo request against
>> that view. If I change the DATA statement to substr(ID, 3,7), removing
>> letters from the ID - getFeatureInfo runs fine for the time being, but
>> without the letters my ID will soon lose its uniqueness.
>> Is MapServer able to server a getFeatureInfo request against DATA that
>> uses a unique text-column containing letters?
>> Find more detail below:
>> mapfile:
>> CONNECTIONTYPE oraclespatial
>> CONNECTION "GDI/****@ORCL_HOGGNO"
>> #not serving getFeatureInfo
>> DATA "GEOM FROM V_*** USING UNIQUE SST_NR SRID 8307 FILTER VERSION
> 10g"
>> #serving getFeatureInfo
>> DATA "GEOM FROM V_*** USING UNIQUE substr(SST_NR,3,7) SRID 8307
> FILTER
>> VERSION 10g"
>> FILTER "BEREICHKZ = '3'"
>> log:
>> Fri Feb 23 10:54:40 2007 - msOracleSpatialLayerGetShape(): OracleSpatial
>> error. Error: ORA-01722: invalid number
>> . Query statement: SELECT ***,***, GEOM FROM V_*** WHERE SST_NR = 0 AND
>> BEREICHKZ = '2' .Check your data statement.
>> SST_NR in this case should not be null, but sth. like 'SS0023093 '.
>> Cheers
>> Sebastian
>> WhereGroup GmbH & Co. KG
>> Siemensstraße 8
>> 53121 Bonn
>> Fon: +49 (0)228 / 90 90 38 - 24
>> Fax: +49 (0)228 / 90 90 38 - 11
>> mailto:sebastian.schmitz at wheregroup.com
>> http://www.wheregroup.com
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Arnulf Christl, Olaf Knopp, Peter Stamm
>> Amtsgericht Bonn, HRB 9885
Siemensstraße 8
53121 Bonn
Komplementärin:
vertreten durch:
