Use of a varible name in TEMPLATE String
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Wed Jan 3 21:37:10 EST 2007
Not as the code sits. That's not a parameter that is currently processed
for runtime variables. You can switch entire templates with
map_web_template (in combination with templatepattern). It's a
relatively easy hack to change mapserv.c to do this, a bit harder in
upcoming releases that provide a mechanism to validate runtime
substitutions, but still doable.
Steve
>>> Dave Potts <dave.potts at PINAN.CO.UK> 01/03/07 6:14 PM >>>
Hi Folks
Is it possible to say something like this in a .map file
WEB
TEMPLATE
"../WEB-INF/post_transform_directory/en_gb/%platform%dataxml"
IMAGEPATH "../tmp/"
IMAGEURL "tmp/"
LOG "/tmp/map.out"
END
Where %platform% is a varible name.
regards
David.
