SLD troubles -desperate!
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Thu Jan 4 12:18:52 EST 2007
Good news!
Assefa: perhaps a check is in order in the code to see if OGR is on
(this should probably be a check in the build process too, or instead)?
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of edfialk
> Sent: 04 January, 2007 12:14 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] SLD
> HURRAY! That did it. Thanks so much everyone that helped.
> All I did was recompile with --with-ogr=path and bam it worked.
> thanks again!
> -Ed
> Yewondwossen Assefa wrote:
> > Hi There,
> > OGR is also a needed library (for geometry conversions). Is it
> > possible for you to test it with OGR enabled (USE_OGR flag)
> ? If that
> > is the case I will update the docs to reflect it.
> > Later,
> > Edward Fialkowski wrote:
> >> I have been unable to get my WMS capable MapServer to recognize an
> >> sld passed in through the url (SLD=http:...)
> >> The sld is readable, I have tested it on an example from the SLD
> >> documentation - i.e. written my own SLD and pointed to it from the
> >> example, works perfectly.
> >> I am totally out of ideas as to why I cannot get it to
> show up on my
> >> own server.
> >> I'll give as much information as i can, any help would be
> extremely
> >> appreciated.
> >> map file:
> >> MAP
> >> NAME "All"
> >> STATUS on
> >> SIZE 800 600
> >> EXTENT -2200000 -712631 3072800 3840000
> >> UNITS METERS
> >> SHAPEPATH "/var/www/html/mapserver
> >> /mapdata/"
> >> IMAGECOLOR 220 220 220
> >> FONTSET "/var/www/html/mapserver/mapdata/"
> >> WEB
> >> IMAGEPATH "/var/www/html/tmp/"
> >> IMAGEURL "/tmp/"
> >> METADATA
> >> "wms_title" "All"
> >> "wms_onlineresource"
> >> "http://niceguy.wustl.edu/cgi-bin/mapserv.exe
> >> <http://niceguy.wustl.edu/cgi-bin/mapserv.exe>?"
> >> "wms_srs" "epsg:4326"
> >> END
> >> END
> >> PROJECTION
> >> "init=epsg:4326"
> >> END
> >> LAYER
> >> NAME NAmer_bdr
> >> METADATA
> >> "wms_title" "NAmer_bdr"
> >> END
> >> TYPE LINE
> >> STATUS on
> >> DATA bound_p
> >> PROJECTION
> >> "init=epsg:4326"
> >> END
> >> CLASS
> >> STYLE
> >> OUTLINECOLOR 0 0 0
> >> END
> >> END
> >> END
> >> SLD File:
> >> <StyledLayerDescriptor version="1.0.0">
> >> <NamedLayer>
> >> <Name>NAmer_bdr</Name>
> >> <UserStyle>
> >> <Title>NAmer_bdr</Title>
> >> <FeatureTypeStyle>
> >> <Rule>
> >> <LineSymbolizer>
> >> <Geometry>
> >> <PropertyName>center-line</PropertyName>
> >> </Geometry>
> >> <Stroke>
> >> <CssParameter name="stroke">#00FF00</CssParameter>
> >> </Stroke>
> >> </LineSymbolizer>
> >> </Rule>
> >> </FeatureTypeStyle>
> >> </UserStyle>
> >> </NamedLayer>
> >> </StyledLayerDescriptor>
> >> and just in case:
> >> [root at niceguy mapserver-4.10.0]# ./mapserv -v MapServer version
> >> 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> >> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> >> SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=GDAL INPUT=SHAPEFILE
> >> Please, please any help.
> >> Thanks!
> >> -Ed
> > Assefa Yewondwossen
> > Software Analyst
> > Email: assefa at dmsolutions.ca
> > http://www.dmsolutions.ca/
> > Phone: (613) 565-5056 (ext 14)
> > Fax: (613) 565-0925
> http://www.nabble.com/SLD-troubles--desperate%21-tf2909232.htm
l#a8163045
> Sent from the Mapserver - User mailing list archive at Nabble.com.
