WCS output formats?
Norman Barker
nbarker at ITTVIS.COM
Tue Jan 9 13:36:09 EST 2007
Ed,
Ho, ho, ho - good old quicktime!
Save the image from the browser and open it in a GIS, or use OpenEV
which works perfectly! MapServer is serving float32, it is a client
error!
I quite often use the curl windows binary for dos to navigate around
these debug errors.
Norman
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of edfialk
Sent: 09 January 2007 16:42
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WCS output formats?
That tutorial did help, thank you for writing it.
I'm thinking we're going to go with GeoTiff and try to convert it
afterward
to something else.
I have managed to serve up geoTiff images, but it seems I can't serve
FLOAT32 GeoTiffs.
All the other imagemodes (RGB, BYTE, INT16, etc.) all work fine, but
when i
set it to Float32, I get the quicktime icon with a question mark in
front of
it, no errors or anything.
Anyone have any ideas why I can't serve Float32?
Thanks again!
-Ed
View this message in context:
http://www.nabble.com/WCS-output-formats--tf2942688.html#a8241448
Sent from the Mapserver - User mailing list archive at Nabble.com.
