[Fwd: Re: [UMN_MAPSERVER-USERS] symbols in mapfile or
symbolset file?]
Kai Behncke
kbehncke at IGF.UNI-OSNABRUECK.DE
Thu Jan 11 07:38:56 EST 2007
On Thu, 11 Jan 2007 13:28:59 +0100, Dolf Andringa wrote
> sorry, meant to send it to the mailinglist, not just Kristian.
> -------- Originele bericht --------
> Onderwerp: Re: [UMN_MAPSERVER-USERS] symbols in mapfile or symbolset
> file?
> Datum: Thu, 11 Jan 2007 13:28:13 +0100 Van: Dolf Andringa
<dolf.andringa at elcyion.nl>
> Aan: Thy, Kristian <Kristian.Thy at ATKINSGLOBAL.COM>
> Referenties: <CE2BE61DABB9384A934BD4E648DFDA37B7E86D at EXCVS1.rdg.bane.dk>
> Ok,thanks. I don't think it is possible to do this with mapscript though
> is it? It would be nice if there was an addSymbol method on the
> mapObj object in mapscript which allows you to add symbols to the
> map declaration. Or am I completely missing something?
> Dolf.
Hi Dolf,
normally you need to define symbols by yourself, or you use code that other
user have produced.
One example to define it inside a mapfile:
SCALEBAR
STATUS embed
TRANSPARENT off
INTERVALS 4
SIZE 200 3
UNITS kilometers
COLOR 250 250 250
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 100 100 100
STYLE 0
POSTLABELCACHE true
LABEL
COLOR 0 0 90
#OUTLINECOLOR 200 200 200
SIZE small
END
END
# SYMBOLS USED IN PMAPPER
# - 'circle' always necessary (used e.g. for highlight)
# - 'square' used in currecnt map file
# Symbols can also be defined via tag SYMBOLSET (see above)
Symbol
Name 'circle'
Type ELLIPSE
Filled TRUE
Points
1 1
END
END
Symbol
Name 'square'
Type VECTOR
Filled TRUE
Points
0 1
0 0
1 0
1 1
0 1
END
END
#================== START OF LAYER SECTION =====================#
LAYER
NAME "jpl_wms_global_mosaic"
TYPE RASTER
STATUS OFF
CONNECTION
But in my opinion, if you have quite a lot symbols:
Use the symbolfile for it. Its cleaner,
Regards, Kai
Dipl.-Geogr. Dipl.-Umweltwiss. Kai Behncke
Institut für Geoinformatik und Fernerkundung (IGF)
Universität Osnabrück
Kolpingstr. 7
49074 Osnabrück
Raum: 01/308
Tel.: +49 541 969-4450
E-Mail: mailto:kbehncke at igf.uni-osnabrueck.de
Web: http://www.igf.uni-osnabrueck.de
