MapServer Version
Eduardo Patto Kanegae epk.lists at GMAIL.COM
Mon Jan 15 02:31:48 PST 2007
Or you can also the simple way: install latest FWTools (
fwtools.maptools.org ).
It contains a mapserv.exe
http://www.webmapit.com.br
On 1/15/07, Zhonghai Wang <zhonghaiw at gmail.com> wrote:
> Hi Guys,
> today I've doenloaded the new MS4W package ms4w 2.2.1.zip here:
> http://www.maptools.org/ms4w/index.phtml?page=downloads.html,
> but when I use -mapserv -v to check the version, it returns:
> MapServer version 4.8.3
> OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
>  OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPO
> RTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPO
> RTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=ORACLESPATIAL
> INPUT=OGR
>  INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> does that mean this package is not using the new MapServer 4.10.0 source?
> Should I compile it myself from source code if I want to use the latest
> version?
> thanks for your information.
> Zhonghai
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070115/0acc61ff/attachment.htm>
More information about the MapServer-users mailing list
