JOIN object usage in a mapfile {Scanned}
    Jeff McKenna
    jmckenna at DMSOLUTIONS.CA
    Mon Jan 15 06:33:18 PST 2007
Thanks Zoltan, that was it.
I'll include my example on the join page.
jeff
Siki Zoltan wrote:
> Hi Jeff,
> You should refer to the column in the joined table in your template like
> [joinname_columnname]
> In your case it should be
> [test_VAL]
> Be carefull with the upper and lower case letters!
> Zoltan
> On Sun, 14 Jan 2007, Jeff McKenna wrote:
>> Hello everyone,
>> For the first time I am trying to use the mapfile JOIN object, and I
>> can't seem to get it to work.  From the mapjoin.c file I can see that
>> DBF, CSV, PostgreSQL, and MySQL are supported.  I have personally tried
>> to view query results joined from DBF, CSV, and PostgreSQL tables
>> unsucessfully.  (my goal is to also update the sparse documentation for
>> this also on http://mapserver.gis.umn.edu/docs/reference/mapfile/join).
>>   Here is my DBF test case:
>> Test Environment
>> mapserver 4.10.0
>> windows
>> mapfile layer
>> LAYER
>>    NAME prov_bound
>>    TYPE POLYGON
>>    STATUS DEFAULT
>>    DATA prov
>>    CLASS
>>      NAME "Province"
>>      STYLE
>>        OUTLINECOLOR 120 120 120
>>        COLOR 255 255 0
>>      END
>>    END
>>    TEMPLATE "../htdocs/cgi-query-templates/prov.html"
>>    HEADER "../htdocs/cgi-query-templates/prov-header.html"
>>    FOOTER "../htdocs/cgi-query-templates/footer.html"
>>    JOIN
>>      NAME "test"
>>      TABLE "../data/lookup.dbf"
>>      FROM "ID"
>>      TO "IDENT"
>>      TYPE ONE-TO-ONE
>>    END
>> END # layer
>> ogrinfo
>>  >ogrinfo lookup.dbf lookup -summary
>> INFO: Open of `lookup.dbf'
>> using driver `ESRI Shapefile' successful.
>> Layer name: lookup
>> Geometry: None
>> Feature Count: 12
>> Layer SRS WKT:
>> (unknown)
>> IDENT: Integer (2.0)
>> VAL: Integer (2.0)
>>  >ogrinfo prov.shp prov -summary
>> INFO: Open of `prov.shp'
>> Layer name: prov
>> Geometry: Polygon
>> Feature Count: 12
>> Extent: (-2340603.750000, -719746.062500) - (3009430.500000, 3836605.250000)
>> Layer SRS WKT:
>> (unknown)
>> Template
>> <tr bgcolor="#EFEFEF"><td align="left">[NAME]</td><td
>> align="left">[VAL]</td></tr>
>> Query Results
>> Layer: Provinces
>> NAME	VAL
>> Ontario	[VAL]
>> Other Notes
>> - the join seems to be happening, because if I specify false FROM/TO
>> values errors are thrown, yet I cannot get values to appear from the
>> [VAL] field
>> - ID/IDENT are integer values from 1 to 12
>> - the join works with desktop GIS packages
>> Can someone see what I am doing wrong?
>> thanks.
>> jeff
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
More information about the MapServer-users
