PHPMapscript : PointObj->draw(...) problem
Stéphane RIFF
stephane.riff at CERENE.FR
Mon Jan 15 10:52:57 EST 2007
Hi everybody,
I have a little problem on the draw function with the pointObj class.
I want to add point dynamically from a postgis database with PHPMapscript.
So I get the coordinates from postgis and draw the point with
pointObj->draw(...) function.
The problem is that my pixmap symbols doesn't have the transparency
activated and my label doesn't have background color.
I use the code below :
$mobileLayer = ms_newLayerObj($map);
$mobileLayer->set("name","Mobiles");
$mobileLayer->set("type",MS_LAYER_POINT);
$mobileLayer->set("status",MS_ON);
$mobileLayer->set("transparency",MS_GD_ALPHA);
$mobileLayer->set("labelcache",MS_OFF);
$mobileLayer->setProjection("init=epsg:4326",MS_TRUE);
$a_class = array();
for($row=0;$row<pg_num_rows($result);$row++)
$lon = pg_fetch_result($result,$row,0);
$lat = pg_fetch_result($result,$row,1);
$ico = pg_fetch_result($result,$row,2);
$sid = pg_fetch_result($result,$row,3);
if(!in_array($ico,$a_class))
array_push($a_class,$ico);
$mobileClass = ms_newClassObj($mobileLayer);
$mobileClass->set("name",$ico);
$mobileStyle = ms_newStyleObj($mobileClass);
$mobileStyle->set("symbolname",$cfg_root."images/symbols/".$ico);
$mobileLabel = $mobileClass->label;
$mobileLabel->set("font","Arialbd");
$mobileLabel->set("size",12);
$mobileLabel->set("type",MS_TRUETYPE);
$mobileLabel->set("offsety",-22);
$mobileLabel->color->setRGB(255,0,0);
$mobileLabel->backgroundcolor->setRGB(255,0,0);
$class_index = 0;
for($cl=0;$cl<$mobileLayer->numclasses;$cl++) {
$class = $mobileLayer->getClass($cl);
if($class->name == $ico) {
$class_index = $cl;
$point = ms_newPointObj();
$point->setXY($lon,$lat);
if($point->draw($map, $mobileLayer, $imgObj, $class_index, $sid) ==
MS_FAILURE)
print("error drawing point");
The result image is like that the one attached :
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070115/e3149f38/Clipboard01.gif
