Problems trying to change projection
Marc Compte
mcompte at SIGTE.UDG.ES
Mon Jan 15 11:13:50 EST 2007
Hi everyone,
We have a Mapserver drawing some layers from a local WMS service. The
WMS service can only provide the data in EPSG:23031 (utm) but we need to
be able to query our Mapserver by using EPSG:4326 (latlong).
If I understood it right Mapserver should be able to change the
projection of my layers, right?
We tried specifying the incoming coordinate system inside the LAYER
object in the mapfile. Then specify the working (output) coordinate
system inside the PROJECTION object in the mapfile.
But when querying the mapserv using geographic coordinates we get a
white image, no data.
Mapfile looks something like ...
PROJECTION
"init=epsg:4326" #longlat datum wgs84 elipsoide wgs84
END
LAYER NAME orto
MINSCALE 100
MAXSCALE 10000
TYPE RASTER
STATUS default
CONNECTIONTYPE WMS
CONNECTION
"http://galileo.icc.es/wms/servlet/icc_orto5m_r_r?REQUEST=map&LAYERS=Ortofoto_5000&STYLES=&FORMAT=png&version=1.1.1"
METADATA
"wms_name" "Ortofoto_5000"
"wms_server_version" "1.1.1"
"wms_srs" "epsg:23031"
"wms_format" "image/png"
END
PROJECTION
"init=epsg:23031"
END
END
In the mapfile we have tried both using the EPSG code and specifying the
proj/datum/ellipsoid, for both the output and the layer definition, and
the result is still the same.
If we specify "proj=utm" (instead of "proj=longlat"), "ellps=WGS84" and
"datum=WGS84" and we query mapserver using utm coordinates we seem to be
getting a good map, with the new datum and ellipsoid. But changing the
projection doesn't seem to work.
Any help will be greatly appreciated. Thanks,
Marc Compte
