Partial labels in mapserver/mapfile
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Jan 18 09:26:50 EST 2007
Frode Wiseth Jørgensen wrote:
> Hi!
> Is it possible to label objects (in mapfile) from a shape-file, by using
> only part of an attribute, or may be manipulate the attribute?
> E.g:
> - Only the first two letters of av word
> - Round numbers (as labeling a numberfield with decimals in a dbf-file,
> would force decimals even if the current attribute has decimals or not)
> Thanks
> FrodeWJ
No, I believe your best bet is to write a script that adds a new column
to the shapefile and populates it with the value that you want to use
for labeling.
You can join multiple fields together, but I don't think you can take a
substring of a field.
You can write the script in mapscript. I don't have any examples handy,
but you should be able to pull some from the list archive or ask the list.
-Steve W.
