WMS tiles & artifacts
Shorthouse, David
dps1 at UALBERTA.CA
Thu Jan 18 14:20:34 EST 2007
Hello folks,
I have been trying to marry MapServer with Google Map with 90% success to
overlay lots of "markers", but when a point generated from a layer in the
mapfile touches the edge of a tile, there's an artifact in the shape of a
horizontal black line. I have seen this before in other implementations &
this artifact is usually the same color as that expressed in CLASS COLOR for
the relevant layer. This artifact doesn't appear in a native MapServer app
using a template so I'm not sure what's going on here. Example:
http://tinyurl.com/37loz7. I have tried playing with the transparency among
other options but to no avail. I also notice that "markers" touching the
vertical sides of a generated tile are often cut-off & don't spill over into
the adjacent tile as they should, but there's no black line. For reference,
this is an OGR connection and the mapfile as I write this is below:
#Note: "---" below indicate stuff I have cleared the purposes of this
posting
MAP
NAME Nearctic
STATUS ON
IMAGETYPE PNG
EXTENT -142 41 -52 85
SIZE 256 256
UNITS DD
SHAPEPATH "---"
IMAGECOLOR 255 255 255
SYMBOLSET "---"
FONTSET "---"
OUTPUTFORMAT
NAME PNG
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
FORMATOPTION "INTERLACE=ON"
TRANSPARENT ON
END
PROJECTION
"init=epsg:54004"
END
LAYER
NAME spiders
CONNECTIONTYPE OGR
CONNECTION '<OGRVRTDataSource>
<OGRVRTLayer name=" ---">
<SrcDataSource>ODBC:---</SrcDataSource>
<SrcSQL>---</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField
encoding="PointFromColumns" x="Longitude" y="Latitude"/>
</OGRVRTLayer>
</OGRVRTDataSource>'
DATA SpiderData
STATUS DEFAULT
TYPE POINT
DUMP TRUE
FILTERITEM ---
FILTER "%---%"
PROJECTION
"init=epsg:4326"
END
CLASS
NAME "< 1900"
EXPRESSION ([Year] < 1900)
COLOR 0 0 0
OUTLINECOLOR 34 139 34
SYMBOL "circle"
SIZE 8
END
CLASS
NAME "1900 - 1920"
EXPRESSION ([Year] >= 1900 and [Year] < 1920)
COLOR 0 0 0
OUTLINECOLOR 0 255 0
SYMBOL "circle"
SIZE 8
END
CLASS
NAME "1920 - 1940"
EXPRESSION ([Year] >= 1920 and [Year] < 1940)
COLOR 0 0 0
OUTLINECOLOR 154 205 50
SYMBOL "circle"
SIZE 8
END
CLASS
NAME "1940 - 1960"
EXPRESSION ([Year] >= 1940 and [Year] < 1960)
COLOR 0 0 0
OUTLINECOLOR 255 255 0
SYMBOL "circle"
SIZE 8
END
CLASS
NAME "1960 - 1980"
EXPRESSION ([Year] >= 1960 and [Year] < 1980)
COLOR 0 0 0
OUTLINECOLOR 255 165 0
SYMBOL "circle"
SIZE 8
END
CLASS
NAME "1980 - 2000"
EXPRESSION ([Year] >= 1980 and [Year] < 2000)
COLOR 0 0 0
OUTLINECOLOR 255 0 0
SYMBOL "circle"
SIZE 8
END
CLASS
NAME "> 2000"
EXPRESSION ([Year] >= 2000 and [Year] ne 9999)
COLOR 0 0 0
OUTLINECOLOR 178 34 34
SYMBOL "circle"
SIZE 8
END
CLASS
NAME "No date"
EXPRESSION ([Year] = 9999)
COLOR 0 0 0
OUTLINECOLOR 201 201 201
SYMBOL "circle"
SIZE 8
END
END
END
Thanks for any ideas,
David P. Shorthouse
Department of Biological Sciences
CW-403, Biological Sciences Centre
University of Alberta
Edmonton, AB T6G 2E9
mailto:dps1 at ualberta.ca
http://canadianarachnology.webhop.net
http://arachnidforum.webhop.net
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070118/b3b01df4/attachment.html
