Raster not displaying correctly
Frank Warmerdam
warmerdam at POBOX.COM
Sat Jan 20 18:19:14 EST 2007
Ian wrote:
> Metadata:
> STATISTICS_MINIMUM=0.0011299999896437
> STATISTICS_MAXIMUM=5.0749998092651
> STATISTICS_MEAN=0.090484300081334
> STATISTICS_MEDIAN=0.060400001704693
> STATISTICS_MODE=0.016850000247359
> STATISTICS_STDDEV=0.263437971404
> LAYER_TYPE=athematic
> The following simple layer draws a black box (which I've read may be a
> data source/extent issue):
> LAYER
> NAME shear
> TYPE RASTER
> DATA /strainMap/shear/shear2.img
> STATUS DEFAULT
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> "datum=WGS84"
> END
> END ## Layer
> What am I missing?
> Thank you!
Ian,
By default MapServer will just cast the pixel values to a byte value
between 0 and 255. It looks like the largest value in your file is 5.07
which would convert to 5 which is still essentially black.
I think you need to apply scaling or classification. I'd suggest reading
the raster access howto for details, but briefly adding the following line
to your layer should allow you to visualize things.
PROCESSING "SCALE=AUTO"
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
