msGetLabelSize() : Could not find/open font {Scanned}
{Scanned}
Aude Allain
aude.allain.ext at MAPPY.COM
Tue Jan 23 03:32:24 EST 2007
These solutions don't work. I have always the same error.
Do you know what is the problem ?
aude
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de Siki Zoltan
Envoyé : lundi 22 janvier 2007 20:27
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: [UMN_MAPSERVER-USERS] msGetLabelSize() : Could not find/open font {Scanned} {Scanned}
1. Try to remove (TrueType) from your font set file.
2. Use slash instead of backslash in the path in the font set file even on
Windows
for example
Arial C:/WINDOWS/Fonts/ARIAL.TTF
Bye,
Zoltan
On Mon, 22 Jan 2007, Aude Allain wrote:
> Hello,
> I'm trying to display labels on my map, but I get the following error :
> : msGetLabelSize(): Could not find/open font.
> I defined a FONTSET FILE in the mapfile which contains font paths :
> FONTSET "../font/fontset.txt"
> Content of fontset.txt :
> Arial (TrueType) C:\WINDOWS\Fonts\ARIAL.TTF
> And, the layer on which I want to see the labels is defined in the
> mapfile :
> LAYER
> NAME " A0"
> CONNECTIONTYPE oraclespatial
> CONNECTION "user at bd/pwd"
> DATA "GEOM FROM MN_A0 USING UNIQUE ID SRID 8307 "
> STATUS DEFAULT
> TYPE POLYGON
> MINSCALE 150
> MAXSCALE 500
> GROUP "Administratif"
> TOLERANCE 100
> TOLERANCEUNITS pixels
> LABELITEM "NAME"
> LABELCACHE on
> CLASS
> NAME "Pays - A0"
> COLOR 255 216 176
> OUTLINECOLOR 32 32 32
> TEMPLATE "ttt_query.html"
> LABEL
> MINFEATURESIZE 1
> MINDISTANCE 1
> POSITION CC
> TYPE TRUETYPE
> FONT "Arial"
> SIZE 12
> ANTIALIAS TRUE
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> END
> END
> END # A0
> The font named 'Arial' is in c:/Windows/font.
> On the Web, it is said to check the Apache user or mapserver has
> permission to access the font file and the ttf files. But I don't know
> how to do that.
> Could you hep me ?
> I use :
> - windows xp
> - ms4w : php/mapscript 4.10, apache 2, php5.2
> - Oracle spatial 10g
> Aude
