WFS in uDig client
Frode Wiseth Jørgensen
frodewj at GMAIL.COM
Fri Jan 26 02:18:49 EST 2007
Hi!
Regarding ArcMap, you do need the Data Interoperability Extension to do it
"the Esri way". Some part of the extension is actually free of charge!
The free part of the extesion allows you to read WFS/GML.
Frode
Neil Best-3 wrote:
> By the way, what about ArcMap? Does anyone have it working in 9.1 or
> 9.2? Is it true that you need the Data Interoperabililty Extension or
> not?
> Neil
>> -------- Original Message --------
>> Subject: WFS in uDig client
>> From: Neil Best <nbest at FORESTONE.COM>
>> Date: Thu, January 25, 2007 12:01 pm
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Can anyone confidently describe the status of connecting to a Mapserver
>> WFS
>> layer using uDig? I am using the 1.1-RC8 version hot off the web and MS
>> 4.99 from FWTools 1.0.7. I can use MS as both client and server and test
>> with shp2img, but when I try it from uDig nothing renders. I can get a
>> feature count, however. Rather than provide further detail I thought I
>> would ask for a sanity check if it can be expected to work or not at this
>> time. My suspicion is that there is a problem with SRS, geomtetry type,
>> or
>> some other metadata due to my ignorance. Does uDig enforce a timeout? I
>> had to bump it up in my client map file to give my PostGIS server time to
>> think. Thanks for any tips.
>> Neil
View this message in context: http://www.nabble.com/WFS-in-uDig-client-tf3118215.html#a8646936
Sent from the Mapserver - User mailing list archive at Nabble.com.
