mapserver ogr connection to tile index
Neil Best
nbest at FORESTONE.COM
Fri Jan 26 15:05:47 EST 2007
What's more when I use this composite layer in a WFS server it appears
that it only serves out one of the tiles, presumably the first one.
Attributes should not be a factor in this case because I am accepting
the default of including no attributes.
> -------- Original Message --------
> Subject: mapserver ogr connection to tile index
> From: Neil Best <nbest at FORESTONE.COM>
> Date: Fri, January 26, 2007 11:01 am
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> In the OGR In Mapserver How-To section 4.5 [1] talks about using a tile
> index for vector layers. I have been able to add a collection of
> shapefiles with differing attribute schemas to my map and they render
> correctly but the attributes are not available for querying, as in an
> on-screen identification.
> LAYER
> NAME "ogrtile"
> TYPE POLYGON
> CONNECTIONTYPE OGR
> TILEINDEX "tileindex.shp,0"
> STATUS ON
> TEMPLATE "query"
> CLASS
> NAME "all"
> STYLE
> COLOR 200 255 0
> OUTLINECOLOR 120 120 120
> END
> END
> END
> The statements in the how-to gave me some optimism that it might work by
> saying "OGR tileindex layers should support all normal query and
> attribute fetching mechanisms" with the qualification that "problems
> may (or may not) be encountered if the component tiles have differing
> schemas (different sets of attributes)," which should have dampened my
> optimism. Anyhow I have tested it out and it seems like I need another
> approach, but I am wondering if anyone has successfully done this and I
> have missed something. Could this possibly be a useful feature?
> Thanks.
> Neil
> [1]
> http://mapserver.gis.umn.edu/docs/howto/ogr_howto/#tileindex-with-ogr
