mapserver + linux centOS + PHP: libpq.so.5 is Missing
{Scanned} {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Sat Jan 27 16:23:59 EST 2007
Hi Raul,
libpq is the C application programmer's interface to PostgreSQL.
Probably the directory of libpq is not defined ld.so.conf or in
LD_LIBRARY_PATH enviroment variable. It is probably in the lib directory
of postgrasql intall directory.
You can use ldd command to check dinamic linked library dependency.
After changing ld.so.conf dont forget to run ldconfig command.
Bye
Zoltan
On Sat, 27 Jan 2007, Raul Retamozo wrote:
> Hello.
> I've been trying to install the folllowing sofware. UMN Mapserver 4.10. + php 5.2 + postgresql 8.2 with OS CentOS 4.3
> I've followed the install notes from this tutorial: http://mapserver.gis.umn.edu/docs/howto/verboselinuxinstall
> About half a year I installed succesfully this software without PHP (of course mapserver was 4.8), with no problems, but, last week i've tried to do tsame in another Server (same OS), but appears an error about libpq.so.5, mapserver looks for this library. I tried recompiling and installing GDAL and GD or looking for each library missing (e.g. libgdal ), but the rror remains.
> Does anyone know how to fix this error and how finish installation succesfully?
> raul n. retamozo velarde
> revelar at hotmail.com
> _________________________________________________________________
> Busca desde cualquier página Web con una protección excepcional. Consigue la Barra de herramientas de Windows Live hoy mismo y GRATUITAMENTE.
> http://www.toolbar.live.com
