ftp image -> Reproject -> WMS
Ed McNierney
ed at TOPOZONE.COM
Fri Jun 1 15:04:14 EDT 2007
Ed -
We do it on TopoZone hundreds of thousands of times every day....
The process is no different than with vector data; you simply specify the
source projection of each layer with a PROJECTION block inside the LAYER
definition, and specify the output projection for the map image with a
PROJECTION block at the top level in your map file.
You will want mapserv -v to report SUPPORTS=GDAL and SUPPORTS=PROJ (it
would be unusual for your distribution to NOT do this), and you will need
to install the PROJ.4 package.
- Ed
Ed McNierney
President and Chief Mapmaker
Maps a la carte, Inc. / TopoZone.com
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: (978) 251-4242
Fax: (978) 251-1396
ed at topozone.com
>> From: edfialk <wef1 at CEC.WUSTL.EDU>
>> Reply-To: edfialk <wef1 at CEC.WUSTL.EDU>
>> Date: Fri, 1 Jun 2007 09:49:37 -0700
>> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
>> Subject: [UMN_MAPSERVER-USERS] ftp image -> Reproject -> WMS
>> Hello, I've been looking through the documentation and haven't quite found
>> what I'm looking for.
>> I was wondering if anyone has seen or knows if this is possible.
>> We have some map images that come from an ftp site, that we overlay on a
>> world borders layer.
>> The map images are a different projection from our borders, so we would like
>> to reproject it.
>> Does anyone know if MapServer can reproject an image file, not a shapefile
>> or netCDF file or anything like that. A picture, a world image in png
>> format.
>> If anyone knows if this is or isn't possible, I would greatly appreciate any
>> bits of info.
>> Thanks!
>> -Ed
>> View this message in context:
http://www.nabble.com/ftp-image--%3E-Reproject--%3E-WMS-tf3853389.html#a10916>>
5
>> 52
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
