Attaching JPEG pictures on a map image.
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Mon Jun 4 02:34:50 EDT 2007
Define a pixmap symbol which uses the image. It will be then rendered
by mapserver exactly where the point is.
Umberto
On 6/4/07, Luca Manganelli <luca76 at gmail.com> wrote:
> Hi,
> I have several small JPEG images (they are tables with values) and I
> would like to "attach" them to the map. Obviously I have the points
> referred to them.
> There's any way to do it?
> "Work only as many hours as you can be productive and only as many hours as
> you can sustain." - Kent Beck, in "Extreme Programming Explained"
> http://www.trapanator.com/blog
