C# Mapscript Project Deployment using ClickOnce
Tamas Szekeres
szekerest at GMAIL.COM
Mon Jun 4 17:28:13 EDT 2007
Jim,
I think we haven't too much experience with ClickOnce but we can
surely support signing the assembly using a pre-generated key pair. If
you are interested in this topic submit a ticket as an enhancement for
the mapscript C# component.
http://trac.osgeo.org/mapserver/newticket
Best regards,
Tamas
2007/6/4, Jim Bartol <jbartol at mmm.com>:
> I have developed a .NET Windows Forms based application that incorporates
> Mapserver, and have successfully distributed it to users by using xcopy
> deployment. I would now like to distribute this application using
> ClickOnce technology. I have been able to successfully publish the
> application using the default settings, however it failed when I tried to
> deploy to a client machine with the following error message:
> ERROR SUMMARY
> Below is a summary of the errors, details of these errors are listed
> later in the log.
> * Activation of C:\ClickOnce Deployments\Rms.application resulted in
> exception. Following failure messages were detected:
> + Manifest XML signature is not valid.
> + No signature was present in the subject.
> I believe this error could occur if the mapscript_csharp.dll assembly was
> not signed when it was created. I have been using the binaries found in
> the sample code posted by David Lowther found at
> http://mapserver.gis.umn.edu/docs/howto/mapscriptcscompile. Has the
> mapscript_csharp.dll in this project been signed? If not, would it be
> possible to post a version of this project where the assembly has been
> signed.
> Has anyone else tried to develop a ClickOnce project with Mapscript?
> Thanks for any feedback on this issue,
> jb
