can anyone help me to check what happen in my zoom and pan control
stin wang
stin.wang at GMAIL.COM
Wed Jun 6 22:18:58 EDT 2007
I'm a newman in Mapserver. i want to use mapserver to distribute some
products in my office such as shape file, modis geotiff,and so on. i study
the tutorial create by Created by Pericles S. Nacionales . i think i grasp
the idea in section one ,that mean i learn how to write my own mapfile. but
i fail in section 2, when i try to imply mapfile into website. i don't
understand how to manage template file.
here is my mapfile
# The annotated map file (sort of)
# Created by Pericles S. Nacionales for the MapServer tutorial
# 20050408
# MapServer map file uses the pound sign (#) to denote the start of a line
# comment--each line that needs to be commented has to be prepended with a
# Map files begin with MAP keyword to signify the start of the map object.
# Well, the entire map file is THE map object. Enclosed between MAP and END
# at the very bottom of this map file, are keyword/value pairs and other
# objects.
MAP
IMAGETYPE PNG
EXTENT 116.701621 38.555172 118.057785 40.251619
SIZE 800 600
SHAPEPATH "../data"
IMAGECOLOR 255 255 255
FONTSET "../fonts/fonts.list"
# Layer objects are defined beneath the map object. You need at least one
# layer defined in your map file before you can display a map... You can
# define as many layers as you'd like although a limit is typically
hard-coded
# in map.h in the MapServer source. The default limit is set at 100.
You'd
# have to have a very specialized application to need more than 100 layers
in
# your application.
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # States polygon layer begins here
NAME county
DATA county
STATUS OFF
TYPE POLYGON
# CLASSITEM defines the non-spatial attribute that you will be using to
# separate a layer into classes. This attribute will be in the DBF file
# of your shapefile (it will be different for each data format). In
this
# example the shapefile states_ugl has an associated database
# (states_ugl.dbf) that contains an attribute called "CLASS". You will
be
# using two values in the CLASS attribute to separate the classes (also
# called themes) used in this layer--land and water. CLASSITEM is used
in
# association with the EXPRESSION parameter in the CLASS object. See
below.
CLASSITEM "ʪÈó"
# Just like CLASSITEM, LABELITEM defines the database attribute that you
# will be using to draw labels. In this case, the values of the
attribute
# "STATE" will be used to label the states polygons.
LABELITEM "UNITENAME"
# The class object is defined within the layer object. You can define
as
# many classes as you need (well, there are limits as with layers, but
it's
# senseless to define more than ten on a "normal" layer. There are
# situations, however, where you might have to do it.)
CLASS
NAME 'VERYGOOD'
EXPRESSION ([ʪÈó] >0.382)
# There are styles in a class, just like there are classes in a layer,
# just like there are layers in a map. You can define multiple styles
in
# a class just as you can define multiple classes in a layer and
multiple
# layers in a map.
STYLE
COLOR 232 121 128
END
LABEL
COLOR 132 31 31
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE TRUETYPE
FONT simhei
SIZE 12
ANTIALIAS TRUE
POSITION AUTO
PARTIALS FALSE
MINDISTANCE 300
BUFFER 4
ENCODING GB2312
END # end of label
# There can be labels in a class, just like there are classes in a
layer,
# just like there are layers in a map. You can define multiple labels
in
multiple
# layers in a map.
# MapServer has a very flexible labeling system. With that
flexibility
# comes complexity, specially when using truetype fonts. Please read
# through the LABEL section of the MapServer map file documentation at
# http://ms.gis.umn.edu/docs/reference/mapfile for more information.
END
CLASS
NAME 'GOOD'
EXPRESSION ([ʪÈó]>0.289 and [ʪÈó] < 0.382 )
STYLE
COLOR 25 123 12
END
LABEL
COLOR 132 31 31
SHADOWSIZE 2 2
TYPE TRUETYPE
FONT simhei
SIZE 12
ANTIALIAS TRUE
POSITION AUTO
PARTIALS FALSE
MINDISTANCE 300
BUFFER 4
ENCODING GB2312
END # end of label
END
CLASS
NAME 'MIDDLE'
EXPRESSION ([ʪÈó]>0.251 and [ʪÈó] < 0.289 )
STYLE
COLOR 255 255 21
END
LABEL
COLOR 132 31 31
SHADOWSIZE 2 2
TYPE TRUETYPE
FONT simhei
SIZE 12
ANTIALIAS TRUE
POSITION AUTO
PARTIALS FALSE
MINDISTANCE 300
BUFFER 4
ENCODING GB2312
END # end of label
END
CLASS
NAME 'BAD'
EXPRESSION ([ʪÈó]>0.179 and [ʪÈó] < 0.251 )
STYLE
COLOR 21 255 243
END
LABEL
COLOR 132 31 31
SHADOWSIZE 2 2
TYPE TRUETYPE
FONT simhei
SIZE 12
ANTIALIAS TRUE
POSITION AUTO
PARTIALS FALSE
MINDISTANCE 300
BUFFER 4
ENCODING GB2312
END # end of label
END
CLASS
NAME 'VERYBAD'
EXPRESSION ([ʪÈó]=0.178 )
STYLE
COLOR 255 12 243
END
LABEL
COLOR 132 31 31
SHADOWSIZE 2 2
TYPE TRUETYPE
FONT simhei
SIZE 12
ANTIALIAS TRUE
POSITION AUTO
PARTIALS FALSE
MINDISTANCE 300
BUFFER 4
ENCODING GB2312
END # end of label
END
END
LAYER # MODIS raster layer begins here
NAME tianjin_modis
DATA "raster/tianjin.tif"
STATUS OFF
TYPE RASTER
PROCESSING "BANDS=1,2,1"
#OFFSITE 71 74 65
#PROJECTION
# "init=epsg:4326"
#END
END # MODIS raster layer ends here
LAYER # RAIL LINE layer begins here
NAME rail
DATA rail
STATUS OFF
TYPE LINE
# Here's an example of the input projection definition.
# EPSG:4326 is code for geographic (latlong) projection
# using the WGS84 datum.
# PROJECTION objects within the LAYER object define the input
# projection--this is the native projection of your data.
PROJECTION
"init=epsg:4326"
END
this
be
in
below.
#CLASSITEM "CLASS"
CLASS
STYLE
SYMBOL 0
COLOR 232 232 0
END
END
END # RAIL LINE layer ends here
LAYER # ROAD LINE layer begins here
NAME road
DATA road
STATUS OFF
TYPE LINE
PROJECTION
"init=epsg:4326"
END
this
be
in
below.
#CLASSITEM "CLASS"
CLASS
STYLE
SYMBOL 0
COLOR 232 90 232
END
END
END # ROAD LINE layer ends here
NAME water
DATA water
STATUS OFF
TYPE LINE
PROJECTION
"init=epsg:4326"
END
this
be
in
below.
#CLASSITEM "CLASS"
CLASS
STYLE
SYMBOL 0
COLOR 232 90 232
END
END
END # WATER LINE layer ends here
LAYER # States line layer begins here
NAME county_line#´Ë´¦×¢ÒâÇø·Ö´óСд
DATA COUNTY
STATUS OFF
TYPE line
CLASS
NAME "State Boundary"
STYLE
COLOR 32 32 32
END
END
END # States line layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # All map files must come to an end just as all other things must come
to...
http://localhost:8080/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/tianjin_test.map&layer=rail&layer=road&layer=county&layer=water&layer=county_line&mode=map
it looks just like what i want..now i want to use this mapfile into a
template,just like turorial doing .
so i add some keword, in the map object before layer object.
TEMPLATEPATTERN 'tianjin_test.html'
WEB
TEMPLATE 'tianjin_test.html'
IMAGEPATH '/ms4w/tmp/ms_tmp/'
IMAGEURL '/ms_tmp/'
END # Every object in MapServer must have an END.;)
# Start of legend
LEGEND
KEYSIZE 12 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
the template file is just like toturial
<html>
<head>
<title>MapServer Workshop</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link type="text/css" rel="stylesheet" href="/tutorial/ms35.css" />
</head>
<body bgcolor="#FFFFFF" text="#000000">
<table width="601" align="center">
<tr>
<td width="593">
<h3 align="center">Example 2.1: Zoom and Pan Controls</h3>
<!-- START OF MAPSERVER FORM -->
<form name="mapserv" method="GET" action="/cgi-bin/mapserv.exe">
<!-- HIDDEN MAPSERVER CGI VARIABLES -->
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="imgxy" value="399.5 299.5">
<table width="400" border="0" align="center">
<tr>
<td>
<table width="400" border="1">
<tr>
<td>
<!-- SPECIFY MAP MODE -->
<div align="center">Map Mode:<br>
<select name="mode">
<option value="browse">Browse</option>
<option value="map">Map</option>
</select>
</div>
</td>
<td>
<!-- FORM SUBMIT BUTTON -->
<input type="submit" name="submit" value="Refresh">
</div>
</td>
<td>
<!-- ZOOM/PAN CONTROLS -->
<div align="center">Map Control: <br>
<select name="zoom">
<option value="4" [zoom_4_select]>Zoom In 4x</option>
<option value="3" [zoom_3_select]>Zoom In 3x</option>
<option value="2" [zoom_2_select]>Zoom In 2x</option>
<option value="1" [zoom_1_select]>Recenter</option>
<option value="-2" [zoom_-2_select]>Zoom Out 2x</option>
<option value="-3" [zoom_-3_select]>Zoom Out 3x</option>
<option value="-4" [zoom_-4_select]>Zoom Out 4x</option>
</select>
</div>
</td>
</tr>
<tr>
<!-- DISPLAY THE MAPSERVER-CREATED MAP IMAGE -->
<td colspan="3" align="center" valign="top">
<input type="image" name="img" src="[img]" width="800"
height="600" border="0">
</td>
</tr>
</table>
</td>
</tr>
</table>
</form>
</td></tr>
</table>
</body>
</html>
so when i open this webpage, it shows me a picture just like what i want
http://localhost:8080/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/tianjin_template.map&layer=county&layer=rail&layer=county_line&zoom=0&mode=browse&root=/tutorial&program=/cgi-bin/mapserv.exe&map_web_template=tianjin_test.html
but problem happens when i click . it should be zoom in or zoom out but
when i click i found nothing anymore, the picture just diappear.
can anyone help me about it??
wangtie
TianJin Meteorological Bureau
TEL
FAX
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070607/c21342c2/attachment.html
