compiling c# mapscript on F7-x86_64
Mike Leahy
mgleahy at GOLDEN.NET
Thu Jun 7 11:00:09 EDT 2007
Hello List,
I just finished upgrading one of my 64-bit machines to Fedora 7. I've
already noticed that binary MapServer packages are installable from the
repositories. However, it seems these lack the csharp mapscript module,
which is something I use frequently. So I did my usual routine to
compile MapServer from source...everything looked okay, until I ran
'make test' for the c# mapscript module (see output below). I haven't
been able to try this on a 32-bit machine, so can only guess that it
might an issue with the 64-bit environment (though FC6-x86_64 with an
older version of Mono seemed to work fine). I'm not sure what to make
of this output from the make test - has anyone seen anything like this
before, or can anyone make any suggestions?
Thanks in advance for any help,
Mike
[mgleahy at localhost csharp]$ make test
LC_ALL=C mono ./shpdump.exe ../../tests/point.shp
Stacktrace:
at (wrapper managed-to-native) mapscriptPINVOKE.delete_shapeObj
(System.Runtime.InteropServices.HandleRef) <0x00012>
(System.Runtime.InteropServices.HandleRef) <0xffffffff>
at shapeObj.Dispose () <0x00067>
at shapeObj.Finalize () <0x00018>
at (wrapper runtime-invoke) System.Object.runtime_invoke_void
(object,intptr,intptr,intptr) <0xffffffff>
Native stacktrace:
mono [0x517025]
mono [0x4ddf9d]
/lib64/libpthread.so.0 [0x3fae00dd20]
/lib64/libc.so.6(cfree+0x3b) [0x3fad073acb]
./libmapscript.so(msFreeShape+0x2c) [0x2aaaab573efc]
./libmapscript.so(CSharp_delete_shapeObj+0x9) [0x2aaaab53cf69]
[0x4001f90c]
Debug info from gdb:
(no debugging symbols found)
Using host libthread_db library "/lib64/libthread_db.so.1".
[Thread debugging using libthread_db enabled]
[New Thread 46912496280112 (LWP 16759)]
[New Thread 1075988816 (LWP 16761)]
[New Thread 1073822032 (LWP 16760)]
0x0000003fae00a597 in pthread_cond_timedwait@@GLIBC_2.3.2 ()
from /lib64/libpthread.so.0
3 Thread 1073822032 (LWP 16760) 0x0000003fae00d3d1 in nanosleep ()
2 Thread 1075988816 (LWP 16761) 0x0000003fad0c9ad2 in select ()
from /lib64/libc.so.6
1 Thread 46912496280112 (LWP 16759) 0x0000003fae00a597 in
pthread_cond_timedwait@@GLIBC_2.3.2 () from /lib64/libpthread.so.0
Thread 3 (Thread 1073822032 (LWP 16760)):
#0 0x0000003fae00d3d1 in nanosleep () from /lib64/libpthread.so.0
#1 0x00000000004c1890 in ?? ()
#2 0x0000003fae0061c5 in start_thread () from /lib64/libpthread.so.0
#3 0x0000003fad0d062d in clone () from /lib64/libc.so.6
Thread 2 (Thread 1075988816 (LWP 16761)):
#0 0x0000003fad0c9ad2 in select () from /lib64/libc.so.6
#1 0x0000003fb1c5646e in g_spawn_sync () from /lib64/libglib-2.0.so.0
#2 0x0000003fb1c56838 in g_spawn_command_line_sync ()
#3 0x00000000005170c7 in ?? ()
#4 0x00000000004ddf9d in ?? ()
#5 <signal handler called>
#6 0x0000003fad073acb in free () from /lib64/libc.so.6
#7 0x00002aaaab573efc in msFreeShape () from ./libmapscript.so
#8 0x00002aaaab53cf69 in CSharp_delete_shapeObj () from ./libmapscript.so
#9 0x000000004001f90c in ?? ()
#10 0x00002aaaaacf8d20 in ?? ()
#11 0x0000000000a86770 in ?? ()
#12 0x0000000000000001 in ?? ()
#13 0x0000003fae00fa28 in g_str_equal () from /lib64/libpthread.so.0
#14 0x0000000000a29390 in ?? ()
#15 0x0000000040223c80 in ?? ()
#16 0x0000000040223ee0 in ?? ()
#17 0x000000004001f862 in ?? ()
#18 0x0000000000a37e68 in ?? ()
#19 0x0000000040223ee0 in ?? ()
#20 0x0000000040223e50 in ?? ()
#21 0x00002aaaaacf8d20 in ?? ()
#22 0x00002aaaaaad3e60 in ?? ()
#23 0x0000000000a86770 in ?? ()
#24 0x00002aaaaacf8d20 in ?? ()
#25 0x0000000000a86770 in ?? ()
#26 0x00002aaaaacf8d20 in ?? ()
#27 0x00000000007ccc08 in ?? ()
#28 0x000000004001f690 in ?? ()
#29 0x0000000000a5f0b0 in ?? ()
#30 0x0000000040223f50 in ?? ()
#31 0x000000004001f5d8 in ?? ()
#32 0x00002aaaaacf8d20 in ?? ()
#33 0x0000000000a86770 in ?? ()
#34 0x0000000000000001 in ?? ()
#35 0x0000000000000011 in ?? ()
#36 0x00002aaaaacf8d20 in ?? ()
#37 0x00002aaaaacf8d20 in ?? ()
#38 0x00002aaaaaad3e60 in ?? ()
#39 0x0000000000a867e0 in ?? ()
#40 0x0000000000000000 in ?? ()
Thread 1 (Thread 46912496280112 (LWP 16759)):
#0 0x0000003fae00a597 in pthread_cond_timedwait@@GLIBC_2.3.2 ()
#1 0x00000000004bf110 in ?? ()
#2 0x00000000004c160d in ?? ()
#3 0x00000000004c5b95 in ?? ()
#4 0x000000000046ccc6 in mono_domain_finalize ()
#5 0x00000000004dc754 in ?? ()
#6 0x0000000000414678 in mono_main ()
#7 0x0000003fad01daa4 in __libc_start_main () from /lib64/libc.so.6
#8 0x0000000000413319 in g_str_equal ()
#9 0x00007fff93e6c348 in ?? ()
#10 0x0000000000000000 in ?? ()
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
make: *** [test] Aborted
