compiling c# mapscript on F7-x86_64
Mike Leahy
mgleahy at GOLDEN.NET
Thu Jun 7 13:05:12 EDT 2007
I ran ./configure for MapServer with all desired options, ran make, then
went into mapscript/csharp and ran make there. Is there something else I
should have done?
On Thu, 7 Jun 2007 18:10:37 +0200, Tamas Szekeres <szekerest at GMAIL.COM> wrote:
>Did you compile the mapserver core and mapscript with the same
>configuration (by using the same GEOS option for example)?
>Best regards,
>Tamas
>2007/6/7, Mike Leahy <mgleahy at golden.net>:
>> Hello List,
>> I just finished upgrading one of my 64-bit machines to Fedora 7. I've
>> already noticed that binary MapServer packages are installable from the
>> repositories. However, it seems these lack the csharp mapscript module,
>> which is something I use frequently. So I did my usual routine to
>> compile MapServer from source...everything looked okay, until I ran
>> 'make test' for the c# mapscript module (see output below). I haven't
>> been able to try this on a 32-bit machine, so can only guess that it
>> might an issue with the 64-bit environment (though FC6-x86_64 with an
>> older version of Mono seemed to work fine). I'm not sure what to make
>> of this output from the make test - has anyone seen anything like this
>> before, or can anyone make any suggestions?
>> Thanks in advance for any help,
>> Mike
>> [mgleahy at localhost csharp]$ make test
>> LC_ALL=C mono ./shpdump.exe ../../tests/point.shp
>> Stacktrace:
>> at (wrapper managed-to-native) mapscriptPINVOKE.delete_shapeObj
>> (System.Runtime.InteropServices.HandleRef) <0x00012>
>> (System.Runtime.InteropServices.HandleRef) <0xffffffff>
>> at shapeObj.Dispose () <0x00067>
>> at shapeObj.Finalize () <0x00018>
>> at (wrapper runtime-invoke) System.Object.runtime_invoke_void
>> (object,intptr,intptr,intptr) <0xffffffff>
>> Native stacktrace:
>> mono [0x517025]
>> mono [0x4ddf9d]
>> /lib64/libpthread.so.0 [0x3fae00dd20]
>> /lib64/libc.so.6(cfree+0x3b) [0x3fad073acb]
>> ./libmapscript.so(msFreeShape+0x2c) [0x2aaaab573efc]
>> ./libmapscript.so(CSharp_delete_shapeObj+0x9) [0x2aaaab53cf69]
>> [0x4001f90c]
>> Debug info from gdb:
>> (no debugging symbols found)
>> Using host libthread_db library "/lib64/libthread_db.so.1".
>> [Thread debugging using libthread_db enabled]
>> [New Thread 46912496280112 (LWP 16759)]
>> [New Thread 1075988816 (LWP 16761)]
>> [New Thread 1073822032 (LWP 16760)]
>> 0x0000003fae00a597 in pthread_cond_timedwait@@GLIBC_2.3.2 ()
>> from /lib64/libpthread.so.0
>> 3 Thread 1073822032 (LWP 16760) 0x0000003fae00d3d1 in nanosleep ()
>> 2 Thread 1075988816 (LWP 16761) 0x0000003fad0c9ad2 in select ()
>> from /lib64/libc.so.6
>> 1 Thread 46912496280112 (LWP 16759) 0x0000003fae00a597 in
>> pthread_cond_timedwait@@GLIBC_2.3.2 () from /lib64/libpthread.so.0
>> Thread 3 (Thread 1073822032 (LWP 16760)):
>> #0 0x0000003fae00d3d1 in nanosleep () from /lib64/libpthread.so.0
>> #1 0x00000000004c1890 in ?? ()
>> #2 0x0000003fae0061c5 in start_thread () from /lib64/libpthread.so.0
>> #3 0x0000003fad0d062d in clone () from /lib64/libc.so.6
>> Thread 2 (Thread 1075988816 (LWP 16761)):
>> #0 0x0000003fad0c9ad2 in select () from /lib64/libc.so.6
>> #1 0x0000003fb1c5646e in g_spawn_sync () from /lib64/libglib-2.0.so.0
>> #2 0x0000003fb1c56838 in g_spawn_command_line_sync ()
>> #3 0x00000000005170c7 in ?? ()
>> #4 0x00000000004ddf9d in ?? ()
>> #5 <signal handler called>
>> #6 0x0000003fad073acb in free () from /lib64/libc.so.6
>> #7 0x00002aaaab573efc in msFreeShape () from ./libmapscript.so
>> #8 0x00002aaaab53cf69 in CSharp_delete_shapeObj () from ./libmapscript.so
>> #9 0x000000004001f90c in ?? ()
>> #10 0x00002aaaaacf8d20 in ?? ()
>> #11 0x0000000000a86770 in ?? ()
>> #12 0x0000000000000001 in ?? ()
>> #13 0x0000003fae00fa28 in g_str_equal () from /lib64/libpthread.so.0
>> #14 0x0000000000a29390 in ?? ()
>> #15 0x0000000040223c80 in ?? ()
>> #16 0x0000000040223ee0 in ?? ()
>> #17 0x000000004001f862 in ?? ()
>> #18 0x0000000000a37e68 in ?? ()
>> #19 0x0000000040223ee0 in ?? ()
>> #20 0x0000000040223e50 in ?? ()
>> #21 0x00002aaaaacf8d20 in ?? ()
>> #22 0x00002aaaaaad3e60 in ?? ()
>> #23 0x0000000000a86770 in ?? ()
>> #24 0x00002aaaaacf8d20 in ?? ()
>> #25 0x0000000000a86770 in ?? ()
>> #26 0x00002aaaaacf8d20 in ?? ()
>> #27 0x00000000007ccc08 in ?? ()
>> #28 0x000000004001f690 in ?? ()
>> #29 0x0000000000a5f0b0 in ?? ()
>> #30 0x0000000040223f50 in ?? ()
>> #31 0x000000004001f5d8 in ?? ()
>> #32 0x00002aaaaacf8d20 in ?? ()
>> #33 0x0000000000a86770 in ?? ()
>> #34 0x0000000000000001 in ?? ()
>> #35 0x0000000000000011 in ?? ()
>> #36 0x00002aaaaacf8d20 in ?? ()
>> #37 0x00002aaaaacf8d20 in ?? ()
>> #38 0x00002aaaaaad3e60 in ?? ()
>> #39 0x0000000000a867e0 in ?? ()
>> #40 0x0000000000000000 in ?? ()
>> Thread 1 (Thread 46912496280112 (LWP 16759)):
>> #0 0x0000003fae00a597 in pthread_cond_timedwait@@GLIBC_2.3.2 ()
>> #1 0x00000000004bf110 in ?? ()
>> #2 0x00000000004c160d in ?? ()
>> #3 0x00000000004c5b95 in ?? ()
>> #4 0x000000000046ccc6 in mono_domain_finalize ()
>> #5 0x00000000004dc754 in ?? ()
>> #6 0x0000000000414678 in mono_main ()
>> #7 0x0000003fad01daa4 in __libc_start_main () from /lib64/libc.so.6
>> #8 0x0000000000413319 in g_str_equal ()
>> #9 0x00007fff93e6c348 in ?? ()
>> #10 0x0000000000000000 in ?? ()
>> Got a SIGSEGV while executing native code. This usually indicates
>> a fatal error in the mono runtime or one of the native libraries
>> used by your application.
>> make: *** [test] Aborted
