Mapserver + oracle spatial
Fernando Simon
fsimon at UNIVALI.BR
Sun Jun 10 21:15:58 EDT 2007
Hi all,
I believe that the problem is with the "*" in your statement. I
already saw some problems when the "*" is used, specially with the query
modes.
In your case I suggest to you to remove the "*" and change it to the
columns from your table. Another hint is to remove the "1 = 1".
Best regards,
Fernando Simon
UMN Mapserver and Oracle Spatial developer
Maher Karim wrote:
> Dear Damien,
> The best way to use such a query is to create a view in Oracle with based
> on your query and it should be in this form of
> create or replace view (viewname) as SELECT
> GEO.GEOM, A.*, ID as UNIQUEID
> FROM
> MAILLES_CIEM GEO ,
> SELECT
> C0.code_geom,
> C0.label_metric LT,
> C0.valeur VT
> FROM
> SIH_CARTE_SIG C0
> WHERE
> 1 = 1
> and session_id = 'b5b89cbf8a613059c7c41b9796c66c44'
> and NUM_COUCHE = '466533b224b29'
> and C0.rang = 0
> ) A
> WHERE
> 1 = 1
> and A.code_geom = GEO.CODECIEM
> and trim(GEO.CODECIEM) is not null
> ORDER BY
> GEO.CODECIEM)
> and use this data in the map file
> data "geom from "Viewname" using unique UNIQUEID"
> Regards
> Maher Abdel Karim
> GIS systems analyst/programmer
> DC Water and Environment
> | | Damien Corpataux |
> | | <damien.corpataux at CAMP|
> | | TOCAMP.COM> |
> | | Sent by: UMN MapServer|
> | | Users List |
> | | <MAPSERVER-USERS at LISTS|
> | | .UMN.EDU> |
> | | 06/05/2007 05:33 PM |
> | | Please respond to |
> | | Damien Corpataux |
> | To: MAPSERVER-USERS at LISTS.UMN.EDU |
> | cc: |
> | Subject: [UMN_MAPSERVER-USERS] Mapserver + oracle spatial |
> Hello list,
> I have a problem with a mapserver oracle spatial laye: when dynamically
> adding a oraclespatial layer with this kind of query:
> GEOM FROM (
> SELECT
> FROM
> MAILLES_CIEM GEO ,
> SELECT
> C0.code_geom,
> C0.label_metric LT,
> C0.valeur VT
> FROM
> SIH_CARTE_SIG C0
> WHERE
> 1 = 1
> and C0.rang = 0
> ) A
> WHERE
> 1 = 1
> ORDER BY
> GEO.CODECIEM) USING UNIQUE UNIQUEID NONE
> any mapserver operation leads to mapserver crash. Has anyone faced this
> situation?
> Here is the output of gdb, when performing a $layer->whichShapes().
> _gdb output_
> #0 0xb7b7b2ac in free () from /lib/tls/libc.so.6
> #1 0xb7b7ccff in malloc () from /lib/tls/libc.so.6
> #2 0xb70101d1 in msOracleSpatialLayerWhichShapes ()
> from /usr/lib/php5/20060613+lfs/php_mapscript.so
> #3 0xb70040e5 in msLayerWhichShapes ()
> #4 0xb6fc87cf in layerObj_whichShapes ()
> #5 0xb6fbb453 in php3_ms_lyr_whichShapes ()
> #6 0xb752972f in execute () from /usr/lib/apache2/modules/libphp5.so
> #7 0xb7519128 in execute () from /usr/lib/apache2/modules/libphp5.so
> #8 0xb7529111 in execute () from /usr/lib/apache2/modules/libphp5.so
> #9 0xb7519128 in execute () from /usr/lib/apache2/modules/libphp5.so
> #10 0xb7529111 in execute () from /usr/lib/apache2/modules/libphp5.so
> #11 0xb7519128 in execute () from /usr/lib/apache2/modules/libphp5.so
> #12 0xb7529111 in execute () from /usr/lib/apache2/modules/libphp5.so
> #13 0xb7519128 in execute () from /usr/lib/apache2/modules/libphp5.so
> #14 0xb7529111 in execute () from /usr/lib/apache2/modules/libphp5.so
> #15 0xb7519128 in execute () from /usr/lib/apache2/modules/libphp5.so
> apache.err (mapserver v4.8):
> *** glibc detected *** corrupted double-linked list: 0x08f74d30 ***
> [Fri Jun 01 16:34:24 2007] [notice] child pid 11105 exit signal Aborted (6)
> apache.err (mapserver v4.10):
> *** glibc detected *** malloc(): memory corruption: 0x08ebe720 ***
> [Fri Jun 01 12:20:01 2007] [notice] child pid 1977 exit signal Aborted (6)
> Best regards,
> Damien Corpataux
> Camptocamp SA
> Damien Corpataux
> PSE A
> CH-1015 Lausanne
> +41 21 619 10 22 (Direct)
> +41 21 619 10 10 (Centrale)
> +41 21 619 10 00 (Fax)
> P Please consider the environment
> Do you really need to print this email?
